K-5 & AF-360 wireless flash underexposed
robheath
Posted 25/10/2011 - 23:01 Link
Hi
I have tried using the following setups with my K-5:
1) Built in flash only
2) AF360FGZ on camera
3) Built in flash as controller, AF360 wireless slave
4) Built in flash as master, AF360 wireless slave
Options 1-3 are consistently well exposed, option 4 is consistently under exposed.
Any thoughts please?
Custom menu "21.Flash in wireless mode" settings:
set to "1 On" for 4) above
set to "2 Off" for 3) above
AF360 set to "Wireless" and "S" of camera, and "On" when on camera
Flickr feedback always appreciated: https://www.flickr.com/photos/robheath/
Pentax K-3/DA 18-135mm WR/DA 18-250mm/DA*50-135/Tamron 70-300/AF360FGZ/Manfrotto 055XPROB/a few other bits and pieces
Klian
Posted 27/10/2011 - 14:02 Link
Hi, I haven't used the AF360FGZ. I'm having the same problem with my k5 & Metz 50 AF1, regardless of program mode P, M, Tv or Av, even setting the EV+ on camera & flash, it was underexposing by the same value, I thought at first the pre flash on camera was triggering the Metz on full power, so adjusted the EV to -2 on camera; still no good.
It's really had me scratching my head, my previous Nikon & Olympus flash worked flawlessly in wireless, just set and get on with it. I phoned Metz, no reported problems but they did say that upgrading the firmware on the K5 to 1.11 may have something to do with it? Very helpful explaining how the camera communicates with the flash but just offered a few suggestions.
I set the K5 to M, shutter 1/180 aperture to F5.6 & lens to 50mm and built in flash to controller mode; bounced flash off the ceiling, near perfect exposure. Set built in flash as master, back to square one. I must be overlooking the obvious but worried there may be something wrong with either the flash or camera.
I've only just got the K5 & Metz, so still finding my way around, but as I said never had a problem with Nikon or Olympus. I hope this information is of some help.
Dangermouse
Posted 27/10/2011 - 17:14 Link
I'm just wondering if this could be something along these lines:
AF360 knows it is running as a wireless slave and sets power output accordingly. However, it doesn't know that the "master" flash is much less powerful than it is, so the result is underexposed?
dangie
Posted 15/11/2011 - 21:16 Link
Just wondering if anyone has had some sucess with this problem as I've just bought the Metz 50AF-1 to use on my K-5 and have exactly the same problem. Perfect when used on camera but grossly underexposed when used wirelessly. Thanks.
6th Year Apprentice Pensioner
robheath
Posted 16/11/2011 - 22:54 Link
Hi Dangie
No luck as yet...I was wondering it this was posted in the wrong forum as there have been so few ideas!
Regards Rob
Posted 17/11/2011 - 17:19 Link
Please see this other thread.
Same offer stands
