Ist DS and K10
Posted 09/07/2009 - 22:24
I would also suggest a wide aperture prime like a 50mm f1.7, for low light shots.
Posted 10/07/2009 - 08:28
I have both cameras, and both produce excellent images. The K10 has the shake reduction of course, and so may be better suited to your candid shots, depending on light.
Posted 10/07/2009 - 10:42
I shot a wedding in June, using a DS on the tripod and a K100DSuper (with SR) for handheld shots. Seemed to make sense to me.
Posted 10/07/2009 - 11:25
You may find you can handle just one camera
I managed fine with the K20D & lenses.
I would be inclined to have the K10D with 16-45 & 50-135 and put a 50mm/1.4 on the *ist-DS
The flow of a wedding doesn't normally require rapid lens changes. If you know the sequence of events you can normally cope
Presumably I'll get better quality shots from the K10 so the 16-45 may be better suited for the "tripod" shots (posed) and the 50-135 on the Ist DS for candid images.
Any thoughts?
K10D
www.photonetics.co.uk
