ISS passage across the sun
Posted 16/08/2016 - 20:26
Hi
Never look at the sun with you naked eye or any unfiltered lens
That said you could make you own filter using baader solar safety film
But it will only be in white light I made one for looking at Mercury transation
http://www.rothervalleyoptics.co.uk/baader-astrosolar-a4-nd50-safety-film-sheet....
cheers Neil
pentax k3
Panasonic Dmc Fz200
pentax k3
Panasonic Dmc Fz200
Posted 16/08/2016 - 20:41
gtis wrote:
Hi
Thanks, Neil. Don't worry, I had absolutely no intention of looking anywhere near the sun with the naked eye. That said, I am sure that some will, sadly.Hi
That's an interesting link — thanks.
I think it's unlikely that i will bother to buy anything just for this event, so I'll probably just leave it to the experts! Maybe one day, I'll get the screw-on safety filter. Not cheap, but could be useful for the next solar eclipse.
Posted 18/08/2016 - 18:40
With a little ingenuity you can arrange a setup to project the suns image onto card & then photograph that.
Welding glass of shade 13 or above held in front of the lens will reduce the light (including UV & IR) to safe levels. It might soften the image somewhat more than solar safety sheet, but it's also VERY much cheaper (My Gold welding glass filters where ~£20, standard green ones are ~£2).
I used projection via a telephoto lens to watch a transit of Venus years ago (but didn't photograph the image) More recently I've taken sun spots via welding glass.
Posted 18/08/2016 - 22:44
For the last eclipse, I discovered that the leader portion (the bit you pull out of the cassette to attach to the take-up spool) of an old set of 35mm negatives was perfect. It is evenly darkened and just the right opacity for staring at the sun's disc.
11 years
My second thought was about the photographic potential (assuming there are no clouds!). Apparently transit will take 0.6 seconds and the local astronomer reckons it's best to take a video. However, he is quoted as saying that specialist lenses would be required.
Is there any way I could capture this event with my K3-II? What focal length lens would be best and how could I video the sun??? I do have a selection of Cokin filters from the old days, but I suspect that I would need something a bit more industrial!!
Any thoughts/advice would be most welcome.
