ISO setting on K20D
Posted 06/04/2009 - 11:44
I guess you have to disable the "200% D-Range" function in the Fn menu where you change the ISO settings, you will find a note in the manual that when this enabled the min ISO is 200 (not 100), as well as some threads on pentax forums discussing this function.
Posted 06/04/2009 - 11:51
andyvarney wrote:
Well I've read the manual - many times - endlessly fiddled with the menu and Fn buttons and I can't see how to do this.
Does anyone know if you can get the ISO below 200? I can get it up to 6400 but can't seem to get it below 200.
Is it me?
Cheers,
Andy
Click "Fn" and then push the "Right arrow key on the round knob" to activate the ISO. Then from that menu as you see the line of ISO settings, press again "Fn" and that will disable the 200% D-Range" HDR
Is it me?
Cheers,
Andy
Amin Photo Gallery
Posted 06/04/2009 - 11:53
If you have "D-range" enabled then you can only go to ISO200.
Press:
Fn, Right, and press Fn again so that "D-range 200%" is NOT showing.
Then you can get ISO100
(It's in the manual )
Press:
Posted 06/04/2009 - 12:11
Fantastic!
Thank you all, you are right it is in the manual but I couldn't find it!
Cheers,
Andy
Cheers,
Andy
It's not the size of the dog in the fight, but the size of the fight in the dog!
Posted 06/04/2009 - 12:28
Press and hold the OK button turn the front wheel to adjust
Posted 06/04/2009 - 14:35
Does that D-range really help, I don't believe it has much function when you shoot in RAW though or am I wrong?
Posted 06/04/2009 - 16:13
Greytop wrote:
Stefan, as far as I can tell when shooting RAW it makes no difference.
Well, some tests seems to show that it actually modifies RAW data. Others tends to think it is actually the RAW converter doing something extra when D-range metadata is found in exif.Stefan, as far as I can tell when shooting RAW it makes no difference.
Some links:
http://forums.dpreview.com/forums/read.asp?forum=1036&message=27181182
There are few other interesting discussions on pentaxforums.com regarding this subject.
http://www.pentaxforums.com/forums/pentax-dslr-discussion/42318-d-range-technica...
Posted 06/04/2009 - 16:16
I believe it does modify RAW data.
What would be interesting is to know whether it does anything you can't do with software in post-processing. I suppose not.
~Pete
Warwickshire
Is it me?
Cheers,
Andy
