Is my 40mm backfocusing
vrapan
Posted 10/07/2011 - 17:38 Link
http://flickr.com/gp/74901137@N00/496f50
The focus point was on the R not the D/F... do you think it is backfocusing? Also even if it does not sure I want to use the auto fine tune cause it seems to not have that problem in closer distances. Thanls
And yes I know I need to clean my keyboard
johnwhit
Posted 10/07/2011 - 18:16 Link
That would be front focusing, would it not?
John
PPG link
In LBA hiatus.
vrapan
Posted 10/07/2011 - 19:14 Link
ok yes sorry ff is it then ?
johnwhit
Posted 10/07/2011 - 19:34 Link
Well it looks like the focus is off, have you tried it a a longer distance?
From the image it does seem a fair way out.
I've micro-adjusted my shorter primes 15-90mm and 2 standard zooms, but not my 135, 200 and 300 as the distance involved made it difficult.
John
PPG link
In LBA hiatus.
vrapan
Posted 10/07/2011 - 20:28 Link
Yes I did and although less visible obviously it still does it. What I also noticed though is that it happens with the 18-55 as well..... Could it be the camera that needs alignment and not the lenses?
Would Pentax be happy to do that ? It might be the reason behind the softness on the 8-16 and the 10-24 as well though if it does it by the same amount give or take for 2 lenses already
Edited by vrapan: 10/07/2011 - 20:29
johnwhit
Posted 10/07/2011 - 20:41 Link
I think I'd be tempted to have the camera checked by SRS if it seems to be the case with all the lenses you've used, maybe others here with experience of the K-5 could suggest something, I only have the K20D.
Just a thought, have you checked the AF adjust menu to ensure there's not an adjustment set for all lenses by any chance?
John
PPG link
In LBA hiatus.
vrapan
Posted 10/07/2011 - 20:45 Link
Ok I will go there the weekend, the AF Adjust was off actually i put 6-7 to bring the 40mm to normal focusing, which is the amount required at the same distance and at 55mm for the 18-55
johnwhit
Posted 10/07/2011 - 20:51 Link
That sounds reasonable, at least it's within the parameters of adjustment. I tend to find that various lenses need different adjutments, be it '-' or '+' but it will vary with individual camera body obviously.
SMCP DA 15mm +5
Sigma AF 24mm -8
SMCP FA 28mm +5
SMCP FA 35mm -3
SMCP FA 50mm -4
SMCP DA 70mm -8
Tamron Di 90mm +/-0
SMCP DA*16-50mm -6
John
PPG link
In LBA hiatus.
Edited by johnwhit: 10/07/2011 - 20:59
vrapan
Posted 10/07/2011 - 21:00 Link
So you recon i shouldnt worry too much? What bothers me is if the camera body is causing it especially seen as it is the same amount for two rather different lenses.
johnwhit
Posted 10/07/2011 - 21:04 Link
I wouldn't worry too much, it could just be coincidence with two lenses however unlikely that may sound. Maybe have SRS take a look if you're passing instead of making a special journey, although I see you're in the Watford area.
John
PPG link
In LBA hiatus.
vrapan
Posted 10/07/2011 - 21:36 Link
Live practically next door and was gonna go next weekend to give another go at the 8-16 so will ask about that. Might instead just drop during lunch time.
Edited by vrapan: 10/07/2011 - 21:37
johnwhit
Posted 10/07/2011 - 21:38 Link
Hope you get it sorted if only to put your mind at rest.
John
PPG link
In LBA hiatus.
vrapan
Posted 10/07/2011 - 21:40 Link
Thanks for all your help John!
johnwhit
Posted 10/07/2011 - 21:45 Link
Glad I could be of some help, enjoy the camera.
Regards,
John
PPG link
In LBA hiatus.
Anvh
Posted 10/07/2011 - 22:04 Link
Now that we have it about focussing, i did some tests and i found that the screw driving lenses i had to use +6 and with the SDM lenses i had to use -6 with the K5 so i'm wondering if that's because of the differnt way the lenses focus.
Did someone notice the same error?
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 10/07/2011 - 22:04
