Intermittent problem with my K20D
Posted 23/06/2009 - 12:45
Yes you did! I'll check it out; thanks Unlocker!!!!
Posted 23/06/2009 - 12:49
After Danny's tip if still not right give Chris a bell first.
Tel,
PHEW! It's all good now. I love this forum!
Posted 23/06/2009 - 12:54
Mike-P wrote:
Have the same problem with my K10D, grip is always the problem.
First time it happened I was in a total panick and reset the whole lot .. was not happy when I realised what it was as it took ages to put back how it was before.
I can imagine! I was certainly panicking, but the intermittent nature of it did make me think there was more to it than meets the eye...
Posted 23/06/2009 - 13:15
Bob
When I first started using the grip I had a few patches also like that,. Then removed the grip and refitted it back and tightened properly, and it hasn't done again.
Seems you might just have had a hiccup and no need to panic ,
at least for the moment
Or it could have been all that excitement of the new DA*50-135 yesterday sending all that static vibe to the camera electronics that messes it up .
Amin Photo Gallery
Posted 23/06/2009 - 13:56
aminstar wrote:
Bob
That's a workable theory Amin!!!
Bob
Posted 23/06/2009 - 14:07
I've also had the problem on both k10 / k20 get's the heart pumping a little
Posted 23/06/2009 - 14:16
It's a bit of a pain, but you soon learn to remember to turn the dials until they click!
The other issue I had was when the front dial didn't work on the grip, took it off to find one of the pins had stuck in a little, probably from putting it on when not 100% aligned. Just pulled it back carefully with some tweezers and been fine since.
Posted 23/06/2009 - 22:46
Ooh Please I know this one --- well sort off.
A while after I got my k20d, I had similar problems. Turned out that what was happening was that I took a shot and tried to change the aperture while the picture was still on the screen. If that is the case, the rear wheel zooms the picture rather than changing the aperture.
Chester
I've already changed it so the front dial can change the aperture in AV mode, and aside from that the only time I use the rear dial is for zooming into a picture and changing the auto ISO range, so I can live with this for a little while (have a few events coming up).
But moving forward this needs to be corrected. The camera was bought from SRS exactly 5 months ago. What's the best thing to do; give SRS a ring, or should I speak to Pentax directly?
Not been in this situation before, so want to know the proper route for after sales support.
My website (Hadfield Photography)
Pentax Gallery Artist page:link
Flickr Photostream: link
