Infinity focus on 18-135
Posted 26/10/2011 - 17:40
I can tell you the review sample I had showed no problem focusing on infinity. I wouldn't expect there to be a problem so you may have a faulty and/or damaged lens.
Posted 26/10/2011 - 17:59
I wonder if others can confirm /refute what John said above.
It can focus on clouds, but if the sky is completely blue it won't focus.
Similarly, won't focus on a uniformly cream coloured wall 6-7 feet away.
Otherwise, I can't fault the lens.
Discovering the joys of photography with Pentax
Posted 26/10/2011 - 18:05
It won't focus on blue sky or on a uniform cream wall and I wouldn't expect any AF lens to do so. AF needs contrast and detail to work.
Posted 26/10/2011 - 18:33
Err
My DA 18-55 WR and Sigma 10-20 does, so did my DA*300
Posted 26/10/2011 - 18:44
As John has said low contrast subjects are not the best to test the AF of a lens, at any distance. However I have a Pentax 50-135 away for repair at the moment that stopped locking on to focus at infinity. According to the repairer it worked fine on his calibration machine, but not on my K5 and K20. It has been returned again and is awaiting parts to adjust the calibration.
Barrie - Too Old To Die Young
Posted 26/10/2011 - 19:19
If you can wait until tomorrow I'll give mine a try. I can't say I have noticed any problems at infinity, but I tend not to try to focus on blue sky or blank walls.
Posted 26/10/2011 - 19:30
Hmm, I have noticed that some or all of my lenses don't focus on blue sky. I however never pay attention to it and just focus on something else that has a bit of contrast. Sorry, I don't have a 18-135 to test.
Posted 26/10/2011 - 21:12
I'm amazed by this. I've never had a lens that will focus reliably on featureless anything at all, be it sky, wall, cloth, or anything else.My DA 18-55 WR and Sigma 10-20 does, so did my DA*300
You're saying you actually get 'green hexagon' focus confirmation, pointing the camera at uniform, featureless, blue sky????
Posted 26/10/2011 - 21:36
As long as it works the other way round..... from blue sky
to earth it should be OK!
Posted 26/10/2011 - 21:46
Oops, actually they have a infinity hard stop which the 18-135 does not
Posted 26/10/2011 - 21:52
True, but you'll still find that with many lenses, the hard stop at the infinity end of the focus throw is actually beyond infinity.Oops, actually they have a infinity hard stop which the 18-135 does not
The green hexagon at the bottom of the viewfinder is the only way of knowing whether the camera has confirmed that it has focused.
Posted 26/10/2011 - 21:56
Actually, I use my sigma 10-20 almost exclusively on MF and hard focused to infinity
Posted 26/10/2011 - 22:26
Well yes, but the depth of field is enormous with extreme wide angle lenses.Actually, I use my sigma 10-20 almost exclusively on MF and hard focused to infinity
If you're going to use a lens as a fixed focus lens and rely on DOF, you'd be better off setting the focus to the hyperfocal distance.
Not the same thing at all as actually being focused on infinity, and nor is turning the focus ring as far as it will go.
Posted 26/10/2011 - 23:53
Probably your best target for infinity focus would be the moon?
In the sky
If you have this lens can you confirm if this is the same for you?
