If you stand, it will land
Posted 04/05/2010 - 18:21
Just getting a feel for the settings Gareth. This lens has been extensively used at distance and I don't have DOF issues. Since trying to use it "too close in" as previously posted shots show, the DOF can be critical. I normally would not use smaller than f/8 but I also wanted to see what can be seen...
Posted 04/05/2010 - 18:34
Did you try to remove noise from the image?. There is surprisingly low level of feather details (for this lens) smooth in places, which look a bit like after heavy denoising.
Posted 04/05/2010 - 18:42
Here is full image from camera. No processing other than sized to 800 pix.Did you try to remove noise from the image?. There is surprisingly low level of feather details (for this lens) smooth in places, which look a bit like after heavy denoising.
Feathers were as original.
Posted 04/05/2010 - 18:44
K10D wrote:
Feather were as original.
Ok, must be a rubbish pigeon then .
Posted 04/05/2010 - 18:47
No answer to that.
I do know that the lens is shhhhaaaarrrrp, Mike-P also has one of these and they are wonderful.
I will endeavour to find a better quality bird......
Posted 04/05/2010 - 19:00
(Had)
K-5; Siggy 10-20 f4, 30mm f1.4, 18-50mm f2.8, 70-200mm f2.8; Tammy 400mm f4, 500mm f8
Posted 04/05/2010 - 19:20
So sharp, it looks almost as if it would fly away if you made a noise.
Colin
Edmund Burke (1729 – 1797)
Posted 05/05/2010 - 03:07
The contrast along the back of the main pigeon is interesting - to me it almost looks like a cut-out placed against that background (I know it's not! ).
Posted 12/05/2010 - 18:44
Know what you mean, i-Berg.
But I saw it as a bigger pigeon partly covered by a black mask of some sort......
Was it?
Roger
Was it?
Roger
Posted 12/05/2010 - 19:00
No mask. Flash can cause some odd effects.
Posted 13/05/2010 - 09:42
Very well taken, it is one of my favourite birds, the use of flash outside for birds, is something I havn`t thought of doing.
Some zooms
https://pentaxphotogallery.com/artists/jack" target="_blank">
http://c759846.r46.cf2.rackcdn.com/img/black_link.jpg" alt="See my photos featured in the PENTAX Photogallery" />
Some zooms
This pigeon landed.
1/180th_f/11_ISO1600
