I-10 pentax
Posted 08/05/2012 - 16:37 - Helpful Comment
Possibly, you have the camera set to record "best performance" on the card thus the sd card has a lot of data to record, which might explain the "lag". Either adjust the recording settings (if you are set on 3-star performance, drop it to 2-star), or consider a Class 16 sd card. Pretec link have a series of these cards, which offer quicker read/write speeds.
Also, if it's possible to update the firmware on this camera, try that too.
** I just had a look at your camera's specs... My guess is that your video card on the lappie is struggling, or you are probably playing back the video in WMV format, which I find to be unstable from time to time. If you have something like Adobe Premier Elements, try converting the video files to either MPEG-4, or AVI. On A desktop with a blu-ray burner, you could probably get a stable playback if you convert it to a Matroska video (MKV) file.
Posted 08/05/2012 - 20:02
cracked it, downloaded media player classic and directex something, vid run through this runs perfec.
Many thanks.
Smudger
Many thanks.
Smudger
Got a pentax I-10, takes great pics but when using in vid mode the playback on camera is fine but when i upload vid via sd card the video staggers, ie not smooth, got a class 10 sd card as avised by Pentax.
I use an Advent 6311 lappie to run pics.
Any help please, i am no techie head but can do simple stuff.
Smudger
