hss and manual lens
Posted 26/09/2016 - 18:57
Joe, the problem is the Manual focus lens ..... HSS is a subset of P-TTL, and P-TTL requires autofocus lenses.
Now, that's my 'official' statement. but. .... You might find it worth trying with an A series lens, set to the A position .... This might work ok
Posted 26/09/2016 - 21:27
Yes, the aperture coupling will get the mechanics of it all working, but we should not expect accurate or reliable flash exposures in P-TTL with Manual Focus lenses. I hope your HSS shots work out well
Posted 27/09/2016 - 12:53
i only want it to be able to hand hold my macro lens as i can get a high shutter speed in poor light to overcome camera shake to help CIF in being accurate and a very shot burst of light that just lights the subject. this is what i got, the background was blacked out easily as it was quite dark anyway
Posted 27/09/2016 - 15:54
It's the results that count, and I think that works beautifully .... Lovely colour balance , and you've certainly knocked out the background with that very short exposure time. The other advantage with flash for this sort of thing is being able to use a smaller aperture, and still handhold.
It's a good place perhaps to note that HSS flash is not necessarily a way to freeze movement ... In fact normal flash is probably better at that, because the flash burst is much shorter .... An HSS flash is effectively a continuous light source that remains on for the max sync time (eg 180th sec), regardless of the actual exposure time, so it can produce more movement effects than normal flash. But in your case here you also wanted to remove the ambient light on the background.
stroud,glos
