How waterproof?
Posted 07/04/2010 - 12:11
WR means weather proof not water proof, they can't stand water pressure.
Only some of the compacts can go into the water.
Posted 07/04/2010 - 12:14
Of course you can go swimming with it, it will likely never work again though
There was a thread recently regarding the weather sealing qualities, general consensus was it was OK in a downpour and whilst you may be lucky and get away with a quick fraction of a second dunking its not worth putting it to the test, the bodies are Weather Resistant not Waterproof.
EDIT: Stefan beat mo to it, serves me right for braking off to put the kettle on
Posted 07/04/2010 - 12:18
The compact PnS W90 is waterproof . . .
Posted 07/04/2010 - 12:39
Posted 07/04/2010 - 12:47
Would the shower work? That's pretty much equivalent to being dunked for a quick second in water. I'm not talking about 5 feet of depth, but rather just touching the top of the water.
K-5; Siggy 10-20 f4, 30mm f1.4, 18-50mm f2.8, 70-200mm f2.8; Tammy 400mm f4, 500mm f8
Posted 07/04/2010 - 12:57
Mike-P wrote:
I thought it was Weather Resistant ..
Well said MikeI thought it was Weather Resistant ..
which is quite different to Weather Proof...
in being almost completely meaningless.
Posted 07/04/2010 - 13:51
and what happens when you slip? if you really must attempt this try enclosing the camera and lens in clear plastic bag with just the front lens element exposed, secure the bag around the lens barrel with a couple of strong elastic bands. You should be able to operate the shutter through the bag.
Posted 07/04/2010 - 20:19
Mike-P wrote:
Well I know you've class ratings in how water resistance something is and I believe pentax doesn't have any rating on their system so Oggy wrote:
I await Stefans diagram with baited breath Quote:
in being almost completely meaningless.which is quite different to Weather Proof...
But that wasnt what you're talking about ^^
Well weather resistance means with me 1m water depth but I wouldn't want to try it out.Would the shower work? That's pretty much equivalent to being dunked for a quick second in water.
I've resined my K10D a couple of times under a tap full open and that never caused me problems but the luck is with the idiot or something like that
Posted 07/04/2010 - 21:46
My diving watch, which is "water resistant to 200metres (unlike me:shock is suitable for dives to 50metres according to the instructions. Um
Posted 07/04/2010 - 22:13
Here Oggy this might help http://en.wikipedia.org/wiki/Water_Resistant_mark
Posted 07/04/2010 - 22:24
Mike-P wrote:
AF Lenses: 10mm-500mm
That's a big range for a zoom?AF Lenses: 10mm-500mm
Digital: K20D+D-BG2 Grip, K10D+D-BG2 Grip, DA* 300 F4, DA* 50-135 F2.8, DA* 16-50 F2.8, DA 17-70 F4, DA 50-200, FA 100-300, AF540FGZ, F Remote release
Analogue: KM, 200mm M,135mm M, K 2x Conv, 28-80mm A, 55mm M, 28mm M, Vivitar 283
Other: Sony PC Digicam,2x Conv,0.7x Sea&Sea wide conv,Sea&Sea Underwater housing, GreenForce 2 x 50W HID lights + double capacity battery, Fujitsu F31 and Underwater housing, Nikon 7900+Underwater Housing
Posted 07/04/2010 - 22:40
whelmed wrote:
So how waterproof are our cameras? Can you go swimming with a Pentax SLR if you've got a WR lens on?
I wouldn't go swimming but I can testify that the DA* 16-50 and K-7 will handle quite heavy rain without a problem So how waterproof are our cameras? Can you go swimming with a Pentax SLR if you've got a WR lens on?
However I think I right in saying that WR lenses are not quite as resistant to the elements as the DA* range
