How to force wireless flash (K100D, af360fgz) ?
Posted 09/05/2007 - 17:24
I have no experience of your flash gun but two points come to mind
First, I presume the gun has a light sensor (else how does it work), so is it in line of sight with the pop up flash?
Second, I have used a hot shoe type sensor on a couple or three third party guns with no problem. Does you gun have hot shoe capability. Of course it will only work in manual mode, but at least it works
Keep up the good work
Graham
I'll think of something someday.
Graham
Posted 09/05/2007 - 17:27
Yes, of course i positioned it to see the other flash. Tried many angles
Posted 09/05/2007 - 17:41
(This is from memory...)
You hold down the LIGHT button on the AF360.
Then press the "S" button until "2" shows. That is the dumb slave mode.
You can use either "M" or "A" mode on the flash gun. However, if you have a static set up, I would suggest using the "M" mode, and setting a power level of 1/2 or lower (i.e. 1/4, 1/8 etc).
Now, on the camera, you just use the pop-up flash. If you've used the "M" mode on the flash, then I'd also suggest using the "M" mode on the camera.
* Set the shutter speed to 1/125
* Guess the aperture, say f/8
* Take a test shot.
- If it's too bright, close the aperture more (higher f-number), and/or move the flash further away
- If it's too dark, either open up the aperture (lower f-number), and/or move the flash nearer
* When you've got a correct flash exposure, then you can choose to lower the shutter speed (assuming you use a tripod). This will enable you to balance the flash with the ambient lighting
The general rule is to make sure the AF360 doesn't dump all it's light on the preflash. When making a test shot you can test in this way:
* Put the AF360 on the desk in front of you, pointing to one side
* Take a shot with the K100D
* If you see the pool of light on the shot, then the flash is triggering
* If you see no light from the AF360, check with your eyes and see if it is triggering from the preflash.
Hope that helps!
EDIT: This shot was taken with the K10D + AF540 with an umbrella and reflector with the method I describe above. Although the K10D supports full wireless, it could easily have been done in dumb mode. In fact... I tested it with a friend's Canon 20D and he was blown away
* Take a test shot.
Hope that helps!
Posted 09/05/2007 - 18:22
Just to follow up on Matt's suggestions... which in the past have been of immense help for me figuring this stuff out. Still, I get VERY erratic behavior when using the pop-up flash and the 360/540 as slaves in dumb-slave wire-less modes. (I have the K10D so that is not strictly necessary as I can use true wireless mode. But the flash communications are long enough that animals and some people are quick enough to have the shot ruined by the time the final flash occurs... so I use dumb slave mode quite often).
Anyway, the only way I have been able to overcome the pre-flash issues is to buy a cheap old dumb flash to stick on the hot-shoe and fire at 1/16 power so that it doesn't affect the scene too much.
This reliably triggers the remote flashes because it has no concept of how to pre-flash and communicate with the camera or other flashes. i.e. it only fires once, and the remote flashes sync perfectly.
Posted 09/05/2007 - 18:32
I've tried it with my Ds, following the instructions given here and in other topics about this, and can't get it to work.
I'm now deciding whether to get all the adapters etc neccesary to use the flash off camera or to fork out on an extra flash. Given that the adapters are hard to come by and will cost around 130 euros in total if I can find them a second flash doesn't sound so bad an investment.
Posted 09/05/2007 - 19:59
Gwyn,
You must missing something somewhere... I have it working just fine with my wife's *ist-Ds.
As I said, it even works with a Canon
Posted 09/05/2007 - 20:47
Matt, I realise it's me not the equipment. I can't figure out what I'm doing wrong. It is very frustrating.
I can see I will end up buying another flash to get over it. Or the K10D of course . (Though having just forked out a fortune on a tripod and head plus some other extras the K10D is a long way off I fear. )
Posted 10/05/2007 - 09:31
One important thing I neglected to mention...
On the AF360FGZ you must also do the following:
* Set the "M C S" switch to "S" = Slave
* Put the power switch to the middle position
The Ready/Test LED should blink about once every second. This means it's waiting for the signal.
Maybe I'll do an illustrated guide....
(Along with the Silkypix guide LOL!)
Posted 10/05/2007 - 10:42
Preferably "after", not "along with". One important thing I neglected to mention...
Posted 11/05/2007 - 18:05
George,
Were you a proof-reader in another life?
Posted 11/05/2007 - 18:18
George,
This wasn't syntactical pedantry. Just an attempt to ensure Matt has his priorities right. George,
Posted 11/05/2007 - 18:41
I get the hint
One day... one day... it's forming in the brain slowly
Posted 11/05/2007 - 19:31
Surely a star like you would have a ghost-writer, Matt?
Posted 11/05/2007 - 20:27
Tim - yeah, I wish
I'm (very very) fast at typing - but it's just getting the stretch of time when I haven't got 5 million other things happening and several tens of thousand lines of C++ code to debug
Latvia
Yes, i've read many forums and specs and now i know it doesn't really work, since K100D doesn't support wireless flash.
But then i found this post saying that af360 could be used in a "dumb slave" mode. http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00KMIS
So i set the thing to Slave2. And it works. I mean, the flash is firing every time i put it close enough to a desktop lamp. BUT it plays dead when i try to trigger i with K100D's pop-up flash. Why? And is there a solution? Should i use specific settings on camera? If so - what exactly?
If there is a way to make it work (in this "dumb slave" mode) please, could you describe it step-by-step? Thanks
