How do you useAF-360Fgz wireless with K10D?
After you set the flash to a channel and wireless you need to pop it on the camera to sync them.
Then you need to press the shutter button halfway down to sync them.
Take a look at the manual here - page 38.
http://www.pentaxslr.com/files/scms_docs//AF360FGZ_REV2_120903.pdf
The options in the Custom menu allow you to set whether the built-in flash contributes to the picture or not; "Master" means it fires as well as the remote flash, "Commander" means only the remote flash fires during the exposure (although the built in still fires prior to the exposure in order to communicate the settings to the remote flash).
See if that works now.
Thank you. I am going to try that later today and see if I can get it to work!
"Controller" means only the remote flash fires during the exposure (although the built in still fires prior to the exposure in order to communicate the settings to the remote flash).
Check out this thread.
It does seem odd that the control flashes coincide with the actual exposure but I suppose there must be a good reason for that...
I imagine the good reason is that it was simply too difficult/expensive/would have taken too long to do it properly, and for most purposes the reduced power at which the builtin fires during the exposure isn't enough to make a big difference.
Life's a compromise, sadly.
It does seem odd that the control flashes coincide with the actual exposure but I suppose there must be a good reason for that... Confused
How would the flash know when to actually fire if the control flash didn't coincide?!
Be aware that the interval between the preflash and the main flash is different (a) on different models of DSLR, (b) if you enable red eye reduction.
If it's in controller mode then the flash is tiny and contributes hardly anything to the exposure. (It has to have some power, otherwise the wireless distance would be useless!)
If it's in master mode then it really does contribute.
In my mind I imagined that the last of the pre-flashes would communicate something along the lines of, "I'm going to open the shutter in x-milliseconds so do your stuff then". The remote would then wait that designated length of time and fire in sync with the shutter, but obviously these systems aren't as smart as I was giving them credit for. Oh well, I suppose there's no real material effect on the picture so I won't be losing sleep over it.
I assumed that the name pre-flash was suggesting that it took place prior to the main flash - I was wrong!
As I said on the other thread, considering the complexity and precision of what happens during leading and trailing curtain sync, I don't think it's all that unreasonable to have thought they'd be able to solve the timing problems.
There was a website somewhere that described the protocol between controller and slave. And it wasn't simple!
Personally, I think the wireless communication is just fine It's only the measurement of the exposure during the preflash phase that could be improved.
Why isn't spot metering an option with the K10D and P-TTL?
It seems that I had some missing information.
If the dumb slave mode is selected, the 'wireless' flash will fire when the cameras pre-flash fires and will be recharging when the main flash trigger signal is sent.
BTW: Wireless in this instance means just that, wire-less = 'not connected by wires'. The actual communication is done using flashes of light from the master/controller flash. Pentax cameras and flashes do not use radio for communication.
22 years
IN camera 1 =built in flash fires as master
2= built in flash as controller
Tried both settings and flash in wireless mode(switch to middle), Tried setting as master, controller, and slave with CH 1,2, and 3. I can't seem to find a combination that works.... very frustrating....
