High ISO Noise Reduction
Posted 07/12/2017 - 00:44
Ditto - apply it where and when you want that way.
9 years
I'm curious to know how many of you use the built in High ISO NR on your camera, and if so do you have certain levels you use for each ISO?
If not, do you use a setting in PP that you prefer as it works better?
Personaly I use the lowest setting on anything up to 800, and theN in crease it above that, but I'm not so sure it doesn't actually add noise?
