Hi all and ???
Ric999
Posted 27/04/2013 - 09:33 Link
Hi all 1st let me thank everyone here for there help in either there posts or articals I have learnt loads from all of you. I have a question that hopefully somebody can help me with. I recently bought a Sirius 60-300mm lens. It was sold as a working Pentax bayonet fitting, apart from that the seller knew nothing else, but for less than £10 I thought what the hell. When I looked at it further I found it was an old Ricoh KR fitting and wouldnt fit my Pentax K-r without removing the pin that was used on the old lens (Using a tip I got from this site it was removed in a couple of minutes). Now the lens fits and looking through it is as clear as a bell, however it will not let me shoot photos and just comes up with the Av option on the led screen. Please does any body know how I could get this working?
Many Thanks
Ric
JohnX
Posted 27/04/2013 - 09:42 Link
Does it have an aperture ring?
Posted 27/04/2013 - 11:07 - Helpful Comment Link
If there are no electronic contacts on the mount you will be limited in how it can be used. Av or M only and stop down metering.
If there is an "A" on the aperture ring then set it to "A" and the lens will work normally.
JAK
Posted 27/04/2013 - 11:46 - Helpful Comment Link
If the lens has an 'A' setting, then use that; the camera will then meter normally, use the camera to dial in the aperture rather than the aperture ring on the lens.
If it hasn't, have a look in the camera manual for 'E-dial in Program' (should be page 105.)
This shows how to set the camera to use the green button to give a shutter speed or aperture value automatically. If you do not have the camera manual handy you can download a copy from the Pentax web site.
Ric999
Posted 27/04/2013 - 13:36 Link
Hi guys thanks a lot with your help, this is why i joined within 2 hours I now have the answer I needed and a lens that is now fully functional. Your advice on this site is fantastic.
cheers
Ric
DaveHolmes
Posted 27/04/2013 - 16:22 Link
Glad it's working for you!
Welcome to the forum!!
Digital:
Flash:
Film:
Ric999
Posted 27/04/2013 - 18:57 Link
Thanks Dave,
Im hoping to take it to my boys football matches tomorrow to get some close ups, its got 2 choices it either behaves or it behaves
AndrewA
Posted 27/04/2013 - 19:20 Link
Welcome to the Forum!
PPG link
Flickr link
