Help please - posting images
Posted 11/02/2006 - 21:22
Posted 11/02/2006 - 22:21
George,
You're trying to be too clever and write HTML code
Use the following:
"[" img "]" full-url "[" /img "]"
Hope that helps.
Use the following:
Hope that helps.
Posted 11/02/2006 - 22:48
I've cracked it now. Isn't it irritating when life is simpler than you thought it was?
Though I still don't know what was wrong with my code.
Posted 11/02/2006 - 23:54
Hi George,
nothing wrong with the code perse, that you used; but as Matt said, you used HTML. If you look at the options panel on the reply form, you'll see that HTML is switched off, but that BB is switched on.
BBCode is the default coding for use with these boards.. click on the link there and you'll get an FAQ on what you can do with it. Some of the formatting is slightly different to what I'm used to at other forums, such as..
Pentax Forum
..doesn't work, whereas..
Pentax Forum
does. Some forums use the " " to enclose the URL, but we don't use them here.
Liam
Pentax Forum
Pentax Forum
Liam
Liam
Posted 12/02/2006 - 00:18
Thanks for the explanation, Liam. I'd never taken on board what BB was before.
Posted 12/02/2006 - 16:48
Do I assume that if I want to post a piccy here, it has to be on a web-host page, and can't be up-loaded (as eg on ePz)?
Andy
Andy
Posted 12/02/2006 - 16:50
Correct. I've managed to hot-link to other sites where I have images, but it doesn't always work. Seems to depend on the site.
Posted 12/02/2006 - 17:29
Thanks for the swift reply, John
Andy
Andy
Posted 15/02/2006 - 15:09
Why can't they make it as easy as ePHOTOzine with the little 'browse' box thing as I can understand that but still cannot understand how to upload on Pentax User so all my loverly Pentax Pics cannot be seen!
Posted 15/02/2006 - 15:16
To be fair, EPZ is intended for uploading pictures, but forums like this one are intended mainly for conversation. The posting of pictures here is probably a secondary thing.Why can't they make it as easy as ePHOTOzine with the little 'browse' box thing as I can understand that but still cannot understand how to upload on Pentax User so all my loverly Pentax Pics cannot be seen!
If it's any consolation, I don't find it easy to do either, but usually because the hosting web sites seem to block the htlinking attempt.
I have you listed on my "Favourites" page for EPZ, so I do see your latest pictures every day.
22 years
London
<img src="http://www.polmed.co.uk/pics/IMGP6345.jpg" width="1024" height="769" border="0">
