Help please - posting images
You're trying to be too clever and write HTML code
Use the following:
"[" img "]" full-url "[" /img "]"
Hope that helps.
Though I still don't know what was wrong with my code.
nothing wrong with the code perse, that you used; but as Matt said, you used HTML. If you look at the options panel on the reply form, you'll see that HTML is switched off, but that BB is switched on.
BBCode is the default coding for use with these boards.. click on the link there and you'll get an FAQ on what you can do with it. Some of the formatting is slightly different to what I'm used to at other forums, such as..
Pentax Forum
..doesn't work, whereas..
Pentax Forum
does. Some forums use the " " to enclose the URL, but we don't use them here.
Liam
Andy
Andy
Why can't they make it as easy as ePHOTOzine with the little 'browse' box thing as I can understand that but still cannot understand how to upload on Pentax User so all my loverly Pentax Pics cannot be seen!
If it's any consolation, I don't find it easy to do either, but usually because the hosting web sites seem to block the htlinking attempt.
I have you listed on my "Favourites" page for EPZ, so I do see your latest pictures every day.
22 years
London
<img src="http://www.polmed.co.uk/pics/IMGP6345.jpg" width="1024" height="769" border="0">
