Help me choose please :)
Posted 25/02/2014 - 22:49
7 and 3
Posted 26/02/2014 - 00:26
3 and 7 for me
Is 3 taken looking over toward Carlingford?
Posted 26/02/2014 - 07:00
looks more like the beach in Newcastle.
Posted 26/02/2014 - 08:47
the very same
Posted 26/02/2014 - 17:17
Stan
There is a lot of it about
Sheffield,
England
No3 is the obvious choice, but not the one I would go for. The stand out for me is the Church shot, but I would give it completely different processing. If it is HDR, I would ditch this approach and process it as a normal image, assuming you have a decent RAW file to work from. The straightening bit is easy - you need to ensure that a vertical line drawn from top of the steeple passes straight through the middle of the Church Door, job done.
I would add some drama to the sky by introducing a subtle graduated fill and then emphasise the shadows in the grass leading up to the church to draw the eye in more effectively. I would increase the contrast and give selected areas of the image a subtle high pass sharpening.
I suspect that your original file of this shot may have some issues, i.e. the sky being a little blown behind the church, but this should not be a showstopper if you process it carefully.
