Help auto focusing in low light
Posted 17/04/2007 - 19:26
Autofocus works by looking for contrast changes in specific strips of pixels (AFAIK), so in low light you are not going to get much contrast in those strips, therefore autofocus wont't work in low light. It's not a pentax thing nor a K10D thing, it's a limitation of the way such systems work. If you have a flash unit such as the AF360, there is a red illuminator which throws a grid of red light onto the object to allow the AF to work in almost totally dark conditions.
Posted 17/04/2007 - 20:17
Lenses with smaller apertures are going to struggle even more. If your lens will only open to f5.6 it will have a lot less light to work with than say a f2.8 or f1.4.
Someone sells a cheap little attachment with a row of LEDs that help illuminate for focusing. But I think they are on all the time, so using the pop-up flash focus-assist or the 360/540 red spotlight is probably going to give better results as they are on only while the button is half-pressed.
Posted 17/04/2007 - 20:46
We all struggle to focus in low light, not just cameras. It's because we use light to focus, and when there isn't any, we have a hard time doing it.
Posted 18/04/2007 - 07:18
Hi Tim,
http://en.wikipedia.org/wiki/Autofocus
Pete, until you get you get a 360 or 540 flash gun, you'll just have to focus manually when it gets too dark for the AF to work.
Liam
For reference Pete..Autofocus works by looking for contrast changes in specific strips of pixels (AFAIK), so in low light you are not going to get much contrast in those strips, therefore autofocus wont't work in low light.
I tried this within an hour of getting my 360. Forget almost.. It works perfectly in total darkness.. perfect focus and exposure every time.. I just can't manage that in daylight.. If you have a flash unit such as the AF360, there is a red illuminator which throws a grid of red light onto the object to allow the AF to work in almost totally dark conditions.
Liam
Liam
Posted 18/04/2007 - 12:48
Pete,
You can help the AF along a bit...
Switch the focus selector on the back to "Centre Only" - point the very middle of the viewfinder on something you can see has contrast and focus with that.
Personally, I find it much easier to use the custom function that disables focus-on-half-press-of-shutter and just use the "AF" button on the back
Generally I can get a focus in very low light if there's a spot of contrast (like the subject's eyes).
But, yes, low light = low contrast = difficulty in getting a focus lock.
And, no, it's not firmware fixable (ALL cameras have this problem in low light, perhaps to varying degrees). But Pentax have given enough custom options to be able to use the camera very, very sensibly.
Posted 18/04/2007 - 13:19
another strategy is to use video lights....has obvious pros and cons...but works great with fast lenses.
Posted 18/04/2007 - 20:59
Aw Liam, did you have go go and blow my cover as an expert (google/wikipedia) user?
West Mids UK
Pete
