Help
Hold down the MENU button and power on the camera, you will see the firmware version on your screen.
Now the filter, that's quite a problem, one reason to get B+W filters
Since the filter turns you can't get a good grip, so move a rubber band around the filter that does not turn it will give you better grip.
If that does not help put it in the freezer, the metal filter will shrink more than the plastic lens making it easier to loosen it.
If that does not help get these link
If that does not help then I don't know either, camera repair shop is then an option.
DA 18-55mm AL WR DAL 50-200mm Tamron 70-300mm, Auto Chinon 28mm 2.8. sigma 30mm 1.4 DC
Metz 48 af-1
I'm serious here, place the sole of the shoe on top of the filter apply some pressure and turn the shoe, with some luck the rubber of the sole catch the filter and turns it so off.
You can't use it with a polarizer because that filter turns in the filter mount.
And here is another tip, lasso a electrical-cord around the filter and use that to turn it.
Most of the time you can't get it loose with your hands because you apply uneven pressure on the filter so basically you make it oval and therefore making it even more stuck then it really is, with a cord the pressure is even, keeping the filter round and that should help quite a bit.
Metz 48 af-1
If you press the filter into the palm of your hand, you apply pressure evenly and rotating your hand might release the filter. It will be covered with grease from your hand, but that's better than a filter jammed in position.
A piece of mouse mat might do very well instead, but I've onlt just thought of that and haven't put it to the test.
Having real probs getting a CPL off my lens ,and i mean real probs it just wont budge .
I use a kitchen rubber glove - gives excellent grip to remove stuck filters.
C
Here is a link: -
http://www.crookedimaging.co.uk/index.php?cPath=26_37
Also you may try an electrical 'tie wrap'
Good luck getting it off.
Paul
Photography is an index for measuring futility and pride.......
Paul
:wink
http://s743.photobucket.com/home/pg20_photos/index https://www.flickr.com/photos/pg20
I tend to keep a thin latex glove in my bag as well.
I should have guessed this would happen because it was always a wee bit sticky to screw on ,no one to blame but myself
Sean
Thanks folks for your input,i think the problem is metal thread on filter and plastic thread on lens not a good combination at all .Not sure about putting lens in the freezer ,the metal ring would only get tighter as the metal would contract i would've though,but if all else fails.
Like you said if all else fails that's on option, wait till a Tuesday and I might have an answer for you if it truly works or not.
About the metal ring getting tighter is not true, like you said it shrinks so the diameter is getting very slightly smaller, it could be just enough to get it loose.
Place a piece across the filter and with your finger widely spread so your grip is all around apply enough pressure to make the matting stick and ease it round.
Don't grip too tight or you will distort the filter (temporarily) and it will not shift - a good widespread grip is what you need - or as suggested use a ty-wrap over the matting - one on each filter and move in opposite directions.
OR
A quick trip down the A939 with it and I'll try for you - provided you don't mind salmon scales and slime over the lens!
K.
My website
Auldearn..Nairn,
Bonnie Scotland
As i'm on here ,i have a question ... would folks on here know or can tell me how to find out what firmware is on the K10D please
Sean
