Help
Posted 29/04/2009 - 05:53
Hi Judith,
Copy the address / link of your picture.
That would be:
http://3.bp.blogspot.com/_cFG8I6Bjo5Q/SffFS2Va-OI/AAAAAAAAAy0/PLvt-F8lxnM/s400/I...
Than press the image button beneath the comment box.
Paste your image address between the two img. brackets.
Et voila............
Martin.
That would be:
Martin.
Posted 01/05/2009 - 04:02
Malo: I am having problem over in the Photo link. My pictures just seem to go away...leaving only an X...I replaced two this evening and after I was done three more Xed out?!
I am also being told my pictures upload too small...They appear fine to me...on my end...but others are seeing them differnly.
I do not know what to do?
As Ever,Judith Ann
As Ever,Judith Ann
Posted 01/05/2009 - 08:40
For the forum, your images need to be set to 800 maximum on the long side.
This can be set on your host website so that everything you upload to it has a predetermined maximum size.
Hyram
Posted 01/05/2009 - 12:32
Hi Judith,
As Hyram told, check out the different sizes available for upload.
There should be different options possible. Choose the link for the 800 pixels on the longest end, and copy / paste as you are used to.
I saw your upload for the fortnightly comp, and it is a bit small.
Martin.
Martin.
Canada;Alberta
Can I upload my pictures I share in the gallery?
Help...and Thanks, Judith ann
