Help! Auto Exposure Bracketing not working with new K10D.
duroo72
Posted 30/03/2008 - 10:09 Link
hello,
im having problems with "AEB" on my new K10D
I have set the aeb frames to 5 and exposure to +2 ev and put the camera into aperture priority with a 2 second shutter delay but the camera refuses to take continuous 5 shots as per the manual.
I have upgraded the firmware to the latest version, reset the camera, tried continuous shooting mode , various manual modes, made sure all the other settings are default , turned cam shake mode on & off , changed the metering and focus modes , changed from 5 frames to 3 frames and decreased the AEB ev levels down one at a time but i just cant get it shoot 3 or 5 frames with one press of the shutter release button. Does anyone know what im doing wrong?!
Gwyn
Posted 30/03/2008 - 10:39 Link
I assume it is the same as on the Ds - you have to keep the shutter pressed until all the frames are taken. Lift your finger off before that and it will stop taking the photos. Same if using a remote control.
duroo72
Posted 30/03/2008 - 11:25 Link
HI Gwyn, thanks for the reply , according to the user manual i shoudlnt have to keep my finger held on the shutter button - the push is all that should be reqd?
GaryMoffat
Posted 30/03/2008 - 12:02 Link
You need to keep the shutter button pressed down. I would use a cable release as it will stop some shake.
The manual is incorrect about only needing one press, I have tried and tried but only found keeping the button down works.
Rgds,
Gary.
pentaxian450
Posted 30/03/2008 - 12:23 Link
Pressing the button once worked with the original firmware, but if you upgraded to firmwdare 1.30, you need to keep the shutter button down for all the sequence to go thru, or release manually for every single shot of the sequence.
duroo72
Posted 30/03/2008 - 12:54 Link
all becomes clear now!
pentaxian would you know if i purchased the wireless remote f or cabled remote and held the shutter release button down on those will the camera take all 3 or 5 shots in one go?
Thanks.
Gwyn
Posted 30/03/2008 - 13:45 Link
If you keep the button pressed on either remote it will take all the shots, but again not if you only press once.
Weird that they changed it in the firmware update though.
duroo72
Posted 30/03/2008 - 17:29 Link
Thankyou Gwyn , i will buy the wireless remote this week and my problems will be sorted! , apart from that i like my new camera very much - the construction and controls are great and im looking forward to doing my first HDR session next weekend.
pentaxian450
Posted 31/03/2008 - 00:54 Link
I don't know either why they changed it, but on the K20D, you can set it either way. Go figure....
duroo72
Posted 11/04/2008 - 21:04 Link
gwyn my first K10d has had to go back due to a fault and i have not had a chance to test the auto bracketing with a cabled remote can you please test this function and let me know if it definitely works as i have the offer of a full refund on the camera?? By the way i had the latest firmware installed.
Many thanks.
amoringello
Posted 11/04/2008 - 23:40 Link
FYI, the normal button and the cabled remote allow me to hold the button down and cycle through bracketed photos.
The IR remote requires that I click for each photo.
For extended bracketing (white balance, sharpness, contrast, etc...) I have to press the button each time regardless of how I take the photo (wired, internal or IR remote).
I have firmware 1.30.
duroo72
Posted 11/04/2008 - 23:43 Link
Howabout "autoexposure bracketing?" i understand that if i use a cabled shutter release i can just keep the button held down and it will shoot all 5 shots in a row?
amoringello
Posted 11/04/2008 - 23:54 Link
Yeah thats what I meant. Sorry if I was ambiguous.
duroo72
Posted 12/04/2008 - 00:00 Link
No Problems , thanks for your input.
Flasharry
Posted 13/04/2008 - 21:31 Link
I'm totally confused by all this. I can find nowhere in the manual where it says a single press is all that's required when using exposure bracketing (quite the opposite in fact) and as far as I can remember my K10D has always required the shutter button to be held down until the last bracketed exposure was taken - even when it was on the 'as supplied' firmware (pre 1.3). Am I missing something here?
Steve.
