Help / Advice needed
Wes4390
Posted 02/07/2012 - 09:59 Link
Just rekindled my interest in photography and new to this foum. I recently bought a secondhand K7, with around 2000 actuations on it. I took lots of snaps since receiving it and at the weekend I noticed a small dot with a small circle around it on all of the images taken with the sky or light background in it. The circle appears around 2 or 3mm in dia when an image is viewed on the computer screen. I went back to the original snaps taken when I received the camera and it appears on those images as well. I have taken the same snap with 2 different lenses and the blemish is still there. Can anyone shed any light on what the problem may be. I have tried contacting the seller but he has not responded yet.......
Posted 02/07/2012 - 10:05 Link
Hi Wes (and welcome) - It may just be a bit of dust on the sensor. If you have the instruction book take a look at the section for sensor cleaning, but take care that you follow the advice properly. Usually locking the mirror up and gently blowing with a "Rocket" type blower is sufficient. You should also be able to do a "sensor check" to first see where the dust is.
Wes4390
Posted 02/07/2012 - 10:17 Link
Thanks for the response......I initially thought it may be a bit of dust but it is absolutely symmetrical, it resembles one of the 'check' boxes on ebay for example, where you click to accept something and a black dot appears inside a circle, although my problem is more of a pale grey rather than defined black.... I will check the sensor anyway to see if it resolves the problem.
Posted 02/07/2012 - 16:06 Link
Can you post an image so we can see the effect?
Wes4390
Posted 02/07/2012 - 21:02 Link
John,
How do I go about posting an image........... if you drop me an email address I could send one by
Wes
Gwyn
Posted 02/07/2012 - 21:42 Link
Wes4390 wrote:
John,
Wes
https://www.pentaxuser.com/forum/topic/how-to-post-images-6624
Wes4390
Posted 02/07/2012 - 22:24 Link
Don't know if this will work, here goes. The blemish is in the sky right had side
http://s1245.photobucket.com/albums/gg598/wes4390/?action=view¤t=IMGP7537_...
Wes4390
Posted 02/07/2012 - 22:40 Link
JohnX
Posted 02/07/2012 - 22:48 Link
Dust!
fatspider
Posted 02/07/2012 - 22:50 Link
As the rest of the sensor looks ok this is obviously something that the cameras dust removal can't shift, and as it's been there so long it's doubtful a rocket blower will help, you need to invest in some wet cleaners.
I doubt it's a fault with the sensor, the halo effect is a characteristic of dirt.
My PPG link
My Flckr link
Wes4390
Posted 02/07/2012 - 23:03 Link
Thanks for the help .......I have used a rocket blower this evening and will buy some wet cleaners tomorrow, any advice on a brand/type. I should say the only shop near to me is Jessops and are they relatively easy to use...........
aliengrove
Posted 04/07/2012 - 01:45 Link
I personally have never found Jessops very easy to use.....
greynolds999
Posted 04/07/2012 - 09:36 Link
Although Jessops may stock these, they will advise you to get it cleaned 'professionally' (which basically means they do it for you and charge £40)!
You need something like this. Visible Dust are a very good brand. You might get cheaper, but don't buy too cheap as it may damage your sensor more than it cleans!
Wes4390
Posted 05/07/2012 - 10:42 Link
Thanks again ..........will give it a go and see if it sorts out the problem
