Have I wrecked my roll of Ektar?
Posted 20/12/2010 - 14:53
plus or minus half? if you over exposed it no problem. if under...
well...
you can push or pull the development time to help fix it...
well...
Posted 20/12/2010 - 14:56
actually the film should be able to handle the underexposure ok as well...
I think you'll be fine but your photofinisher may need to adjust at the printing phase..
Posted 20/12/2010 - 15:22
It was minus half...... Not impressed with myself today!
K5, K200 and several film Pentax cameras!
Posted 20/12/2010 - 15:47
I think a hlaf stop underexposure on print film should be fine... maybe a little more grain...
just mention it to your photofinisher and check your prints and negs when you get them back to make sure your prints are printed right.
Posted 20/12/2010 - 15:54
I've seen the results of underexposing colour slide film by a stop (ISO set wrongly) and to be honest it didn't look that bad, the images were salvageable although obviously some detail had been lost.
Posted 20/12/2010 - 15:56
Hopefully will be ok. The first 5 shots will be ok at least!! At least it was technically a testing roll so nothing really important on it. WIll cross my fingers!
Posted 21/12/2010 - 00:54
I recently underexposed some Fuji Pro 400H 120 film by two and a half to three stops (due to a malfunctioning TTL meter) and still got some rather moody and dark, but useable, prints. The negatives did look rather thin and washed out.
Another time, I overexposed about half a 35mm colour negative film (Fuji Superia 400ISO) by one stop. Didn't do anything about it (other than reset the ISO to the proper setting -400 instead of 200- as soon as I noticed, for the rest of the film), said nothing to the processor, and the exposure of the prints looked identical throughout the roll: you couln't have told. Even the negatives didn't look all that different
Budapest
I am so often a completely useless muppet.
