Have I got a problem with my Sigma 10-20mm
Posted 10/03/2014 - 09:01 Link
Recently I've noticed that I'm getting a green lens effect when shooting from a dark area into light. The attached photograph is part of a bracket of three for an HDR image and the exposure bias was set to +2. You can clearly see what I mean, but I've highlighted it anyway. The other two in the bracket set are showing a similar effect.
Camera is a Pentax K-30, Lens is the Sigma 10-20mm. For this particular photograph Focal Length was f11, Exposure was 1 second and the ISO was 100.
I've never noticed this lens effect before. Does anyone know if it is a problem or just a characteristic of the lens?
spinno
Posted 10/03/2014 - 09:03 Link
Do you have a filter on?
Fletcher8
Posted 10/03/2014 - 09:18 - Helpful Comment Link
No, you have no more of a problem than anyone else with a Sigma 10-20mm who may have experienced similar things.
I am not qualified to go into the science and specifics of light and lenses, but i am sure others will be able to explain how and why this issue can occur. However, it can be easily fixed in processing in Photoshop or other software.
Fletcher8.
Posted 10/03/2014 - 09:35 - Helpful Comment Link
It's flare. The light is reflecting within the lens and causing the double image.
The Pentax SMC coating is very efficient at avoiding flare, and the new HD coating even more so.
Posted 10/03/2014 - 09:53 Link
In reply to David, yes, there is a filter on, but it makes no difference on or off. Fletcher and John, thanks for commenting. I think I need to try the same photograph using a different lens.
