GX20 with Picasa and Silkypix
Posted 08/03/2009 - 08:54
Looks OK Lee, a TV is a very poor test. The camera will struggle working out the White Balance for one thing. Try it outside or photograph a small ornament or even another camera by the light of the window. At a push use the built in flash if their isn't enough light.
I don't think you've anything to worry about.
shim
shim
Posted 08/03/2009 - 09:30
Ha ha
Yes a TV is a rubbish test but it was the only thing I had used RAW+ on (and if I'm honest I couldn't be bothered to go back outside to take another pic of something :blush. You can still see the effect (affect?) between the 2 images though ....
I've updated Silkypix and it's fine now, though I suspect it was actually because I Silkypix had automatically set the 'Color' setting to 'DNG Standard Color' rather than 'Standard Color'. (I only noticed this after I updated Silkypix!).
I have no doubt that Picasa is a similar user error on my part!
Thanks for the replies
North Wales
I've just received my new GX20. It all seems to be going well except for one thing ... When I download images (.dng sRGB) and view them in either Picasa 3 or Silkypix 3.0.16.1 the colours look completely muted and washed out.
I have access to Adobe Photoshop CS3 and everything looks fine there. Also tried changing the GX20 to RAW+ and jpg looks fine.
I changed the settings in my K10D to be .dng sRGB and they display fine? I guess that I need to update the software (though Picasa says it's up to date) as there may be differences in the .dng version?
I know that colour profiles, etc can make a difference but it is totally different on the two machines I have access to at the moment.
Does anyone else have any issue with Picasa or Silkypix with a K20D / GX20?
I can just process my images via Photoshop if required ...
Lee
Example images uploaded here
edit - changed the images in the link
