gx10 problems
jacqui2
Posted 01/10/2010 - 22:09 Link
hi, just received my gx10 today, trouble is, it is constantly under exposing , whetever I put the metering on, it just keeps under exposing shots, any ideas? thanks.
jacqui
gtis
Posted 01/10/2010 - 22:15 Link
hi jacqui
if its like the k200 you might have to adjust the exposure
compensation control
neil
cheers Neil
pentax k3
Panasonic Dmc Fz200
Paul_C
Posted 01/10/2010 - 22:42 Link
I set my k10d to +0.7 on the exposure compensation.
I think they do tend to underexpose but you'll soon get used to it.
fatspider
Posted 02/10/2010 - 00:49 Link
You could start by doing some exposure tests, ideally a piece of nuetral grey card, but we dont all have one of those lying around, try an area of evenly lit grass. Start with a shot using multi segment metering, then centre weighted then spot, if the grass is evenly lit they should all be similar, do this several times to ensure the results are consistant, though bear in mind there will be some variation due to changes in the light.
From this you should be able to determine if the metering is faulty or simply in need of a bit of compensation, you can work out how much by dialing in various amounts until the grass looks correctly exposed.
This wont garuantee your exposures for other subjects but it is a good starting point
EDIT: PS, I see you chose the GX10 then
My PPG link
My Flckr link
Edited by fatspider: 02/10/2010 - 00:52
jacqui2
Posted 02/10/2010 - 01:01 Link
yep, got it. thanks for that I will try it on the grass tomorrow.
jacqui
