Gutted - Anyone do much repair work?
whelmed
Posted 08/04/2010 - 19:19 Link
My friend gave me his SD800 IS P&S camera as he had dropped it and the lens was jammed. Well, I ripped that bad boy down, rebuilt the gears, and it looked great. As I was putting it back together, I ripped one very small flex cable, GUTTED! It's part of the major flex cable assembly and I just couldn't be asked to rip the entire thing out and replace it.
Now, I can probably solder a few connections on both sides and run a lil wire, but it's going to be tight. Has anyone every tried to repair a flex cable? Any pro tips? They're so effin tiny / delicate that I'm going to have to avoid soldering on the cable itself!
K-5; Siggy 10-20 f4, 30mm f1.4, 18-50mm f2.8, 70-200mm f2.8; Tammy 400mm f4, 500mm f8
CoDa
Posted 08/04/2010 - 20:30 Link
I have done a repair like this before, but its a pain to do. I peeled a strip of copper from a printed circuit board and used that.
Steady hands, magnifying lamp, fine tip soldering iron and patience are required.
Good luck
Colin
Edmund Burke (1729 – 1797)
Edited by CoDa: 08/04/2010 - 20:30
geclinke
Posted 09/04/2010 - 13:52 Link
Biggest issue I've had with that sort of thing is the plastic melting away, as soon as a soldering iron comes within an inch of what you want to solder.
Have you considered using conductive paint? Obviously without seeing the problem - don't know if it's an option. I'm sure Halfords used to sell paint for reparing heated rear window matrices in cars - that might do the trick?
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
Lloydy
Posted 09/04/2010 - 18:22 Link
I think RS Components, possibly Maplins as well, do a cold solder which is a conductive resin.
