Guide for shutter speed and focal length
organicimagery
Posted 23/07/2009 - 22:34 Link
Are there any quick guides that you know of for adjusting the shutter speed to focal length,i know its roughly 1.5 x 1.5, also any way of seeing what focal length i am on with out always haveing to look at barral of the lens? thanks
Mannesty
Posted 23/07/2009 - 22:41 Link
If you are using a zoom lens, the only way of knowing what zoom setting you have is to look at the lens barrel.
After the pic is taken you can check the actual zoom setting using Photome.
Before the days of shake reduction (SR) systems the rule of thumb would be to set the shutter speed to the reciprocal of the lens's focal length.EG: for a 400mm lens you would set a minimum of 1/400th/sec shutter speed.
With SR, things have changed, and you can usually get away with at least 2 stops slower shutter, but whether that is appropriate or not depends entirely on your subject, whether it's moving, and how fast.
Anvh
Posted 24/07/2009 - 09:59 Link
About those rules it seems that Pentax is useing a different one.
If you set your camera on an automatic mode, depending on the setting but if the shutter speed is low you see it change when zooming.
Out of my head with the DA*50-135, it use 1/30th with 50mm and 1/125th with 135mm and I must say that I can keep them sharp with those speeds as long as the subject isn't moving.
Th rule is what Peter said shutter speed is lens focal length but that was for 35mm and angle of view is important with this so you need to use 1.5x to get the accurate result.
but most of the time with SR I would say that you don't need the 1.5x any more.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 24/07/2009 - 10:00
