GR Problem?
takuman
Posted 25/10/2013 - 10:35 Link
Hi all. Received my GR. Very pleased. But. Strange thing, (maybe it's me not in the first flush of youth), having taken several shots in B&W High contrast RAW, the image on the screen appears as B&W, however when I load the images onto my PC they appear in colour. If I then take the same shots as JPEG they appear in B&W on both GR screen and PC. Have I missed something? Using PNY Optima 2gb SD card. No problems with this card in K5. Hoping someone will understand what I am describing and help.
Regards to all John
Just passing thru
takuman
Posted 25/10/2013 - 11:26 Link
Follow up from my previous post regarding problem with GR. If I download direct from Camera memory with USB cable (card removed), no problem with image display. If I use card in PC slot all RAW come out in colour, not as set on camera (Hi Contrast B&W). JPEG fine in both cases.
Regards again John
Just passing thru
Edited by takuman: 25/10/2013 - 11:28
punkrockemo
Posted 25/10/2013 - 14:01 Link
I thought, regardless of camera model that all RAW files open in colour and do not incorporate any in camera settings such as Black and white or other colour setting which you are supposed to do on post.
percy
Posted 25/10/2013 - 14:20 - Helpful Comment Link
Somebody please correct me if I state something incorrectly here, but as I understand it a RAW image is unprocessed data which will include all the colour information. You will need to process it in your favourite image editing software and save as a JPEG/TIFF or whatever format you like.
The JPEG image you are taking off your camera is the RAW image which has then been processed in the camera. When you ask the camera for a B&W image it will process the RAW file and save it as a B&W JPEG. The original RAW file will not have any changes applied to it.
Similarly, what you are looking at the image on the camera's screen it will be displaying a processed (JPEG) thumbnail, not the RAW image.
JAK
Posted 25/10/2013 - 14:41 - Helpful Comment Link
The camera is giving you the monochrome jpeg you requested. Having the raw file as well allows you to produce a colour version later if you subsequently change your mind and regret only having the mono version. Best of both worlds!
takuman
Posted 25/10/2013 - 15:13 Link
Thanks guys, once again the forum increases my knowledge base. I can have a decent nights sleep again. Thank you all,
Regards John
Just passing thru
