Giottos ball head panorama knob
Posted 13/10/2013 - 12:48 - Helpful Comment
Aren't you supposed to physically lift the triopod and rotate
everything through 360° and then put it back on the ground
It does sound odd if it's unscrewing though. It sounds like
the 360° rotation yoke is too stiff and it's unscrewing off
the triopod bush..... in which case try to screw it on
tighter. It's not normal to be able to lubricate/repair the
360° rotation yoke
360° rotation yoke
Posted 13/10/2013 - 13:15
That's what I had to do yesterday No, used the ball head
360° rotation yoke
Think I'll check if it's out of warranty if it's a fault, which it seems to be, as it could come off in transit and get lost
360° rotation yoke
Northumberland
When the knob to release the "panorama" section is loosened is the head supposed to be able to be turned 360° without eventually unscrewing from the base or are you supposed to turn it back till it tightens again. Just noticed this yesterday when using it. Hope this makes sense
Stan
