fstops/aperture values
PeteWelshPhotography
Posted 08/03/2009 - 21:21 Link
I notice on my exif data on the photos I have put in my portfolio, that there is an f-stop and also aperture value.. Could someone enlighten me and tell me what the difference is please. I thought the F-stop was the aperture value.. :
Pentax K7 and K5 and several black tubey things with magnifying glass in that twist around and move in and out - to be honest I am not sure exactly what I have. Will list the proper names one day..
Edited by PeteWelshPhotography: 08/03/2009 - 21:22
Posted 08/03/2009 - 21:28 Link
Perhaps it refers to the use of zooms, where the set aperture value could be say f8 but the actual f stop will vary as you zoom.
If this is the case, with a prime the values should always be the same.
Posted 08/03/2009 - 21:43 Link
The photos were taken on a zoom lens john so you may be right there ... It just confused me as I would have thought if the f-stop was set at F8 it would not differ.
Anvh
Posted 08/03/2009 - 23:21 Link
f-stop is also called focal ratio.
It's the ratio between the focal length and the diameter of the entrance pupil (aperture).
finally something that's easy to explain
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 08/03/2009 - 23:21
Father Ted
Posted 09/03/2009 - 08:29 Link
I'm glad Pete asked as this has confused me also.
So, just to take this one step ( or should that be stop? ) further; why are the aperture settings marked as f3.5, f22 etc if they are not directly the f-stops? Or is this a throw back to the early days when all lenses would have been fixed focal length.
Also, again from looking at older lenses, I'd been led to believe that the f-number was the approxomate DoF range. So, at f22 I'd get 22metres in focus spread out as 1/3 in front of object and 2/3 behind. Is that correct?
Posted 09/03/2009 - 09:45 - Helpful Comment Link
No.
The f stop is a ratio, f1.4 is one stop wider than f2 and we know that the square root of 2 is 1.4 (OK, 1.414 or so before someone jumps on that!) so that shows the mathemeatical relationship.
If you have a simple lens of 25mm diameter and a focal length of 50mm this nice easy example is f2. (50 divided by 25)It's as simple as that. The beauty is that it holds true for any lens of any foacl length. If the same 25mm diameter lens had a focal length of 100mm it would be f4. (100 divided by 25). So to make a f2 100mm lens we would need a lens diameter of 50mm...much larger glass.
This is why long fast lenses are enormous and wide angle fast lenses can be much smaller. This latter point falls apart because SLR wide angles have to be retrofocus in design to clear the flipping mirror, so the front glass can be quite large, but the actual exit aperture (look through the back of the lens) is small.
Apertures like f3.5 are half values. The full sequence is 1.4, 1.7, 2, 2.3, 2.8, 3.5, 4, 4.5, 5.6, 6.3, 8, 9.5, 11, 12.5, 16........etc. Some photographers (and Canon) will "simplify" things by calling apertures things like "f 8 and a half" but that doesn't really help to clarify!
T stops are transmission stops, sometimes found on old cameras. A four element uncoated lens might lose 35% of its light to internal reflection, so a physically sized f2.8 lens might have an actual transmmission of T3.5 or T4. This isn't a problem with SMC lenses, but even 0.2% per surface loss can mount up in a 15 element lens. Auto exposure takes care of any slight error because of light loss. So T stops are now obsolete.
I should have made this an article....
Edited by johnriley: 09/03/2009 - 09:45
fatspider
Posted 09/03/2009 - 09:55 Link
Or written a paper on it, maybe hoped for the Nobel Prize
My PPG link
My Flckr link
Father Ted
Posted 09/03/2009 - 10:22 Link
Thanks for clearing that up John.
I think
So is there any way to know from an F stop what my DoF would be at any given distance? Or does that come from experience?
amoringello
Posted 09/03/2009 - 10:48 - Helpful Comment Link
Yes. Look up 'hyperfocal distance calculator' on google.
Although the Hyperfocal distance is geared for determining how to get your entire image "in focus", the calculators will often give you the DOF for any general focus and aperture configuration.
A good example is here:
e.g. http://www.dofmaster.com/dofjs.html
Edited by amoringello: 09/03/2009 - 10:50
Father Ted
Posted 09/03/2009 - 11:40 Link
Posted 09/03/2009 - 11:55 - Helpful Comment Link
Every lens will have a Depth of Field table and someone recently gave us a link to the Pentax website which apparently has them all.
Older instruction manuals used to contain DOF tables.
Posted 09/03/2009 - 12:13 Link
Thank you John .. You really are a mine of information.
At the risk of sounding pedantic (which I'm not being) Why would you need to know all of that information (which I can't get my head around any how ) And what sort of situations would it be used in please.
gartmore
Posted 09/03/2009 - 12:14 Link
Sorry to be picky, John, but T stops are far from osolete. They are used on motion picture camera lenses. The T stop for setting aperture and the F stop for calulating DOF. There can be quite a difference the CZ 25mm f1 (yes f1) Distagon for Super 16 has an f stop of 1 and a T stop of 1.2 The lens has indices for both values.
Posted 09/03/2009 - 12:17 Link
It's like all knowledge, it's interesting. But as to why in practice, well I've never referred to a DOF table yet. If I had a very specific DOF requirement that might be different, but I don't.
The rule of thumb to use a small aperture and focus one third of the way into a scene is as much as I ever use. I even use that for small product shots - look at my eBay page for over 100 current examples!
Posted 09/03/2009 - 13:23 Link
No problem, but I thought I'd covered enough without bringing in Movie lenses as well...as far as amateurs and still cameras go they are obsolete.
I suppose some collectors will use cameras with T stops though, and some will use cameras with non-standard aperture values and shutter speeds. It gets more and more complicated the more you think about it.
