Front/back focus on K200d
Posted 14/03/2009 - 16:00
You could try either of these:-
For K10D with firmware version 1.10.
1. Power OFF
While pressing [PLAY]+[OK], turn the camera on.
Firmware is desplayed on LCD.
then press [Fn]->[Fn]->[INFO]->[MENU] within 5 seconds.
You can see DEBUG mode screen.
By pressing [Right key],Make [DEBUG MODE DIS] to [DEBUG MODE EN].
Then, Press [OK].
2. Press [MENU] and go to SETUP tab.
then, Press [Up key], you can see TEST MODE.
Select AF TEST.
By pressing [Down key], select FOCUS CORR.
If you have Front-focusing, reduce the value.
If you have back-focusing, increase the value.
press [OK] and quit out of setup menu.
3. Test your camera for correct focus.
(repeat step 2. until you are satisfied with the result.)
4. Power OFF
By pressing [Right key],Make [DEBUG MODE EN] to [DEBUG MODE DIS].
Then, Press [OK].
For DL,DS,DS2,K100D :
1. Power OFF
While pressing [AE-L]+[INFO], turn the camera on.
Press [MENU]->[MENU]->[INFO] within 5 seconds.
Then, Press [OK].
2. Press [MENU], you can see setup menu.
By pressing [Up key], select AF TEST.
By pressing [Right key], go into AF TEST menu.
now you can adjust shift amount by pressing [right key] or [left key].
(*Don't touch AF Area Test.)
after changing the value, Press [OK] to save.
4. Power OFF
Then, Press [OK].
1. Power OFF
Then, Press [OK].
Select AF TEST.
4. Power OFF
Then, Press [OK].
1. Power OFF
Then, Press [OK].
4. Power OFF
Then, Press [OK].
Posted 14/03/2009 - 16:13
holding the menu button when turning the camera on shows the firmware version,
Posted 14/03/2009 - 18:09
I've tried the K10d way, it doesn't work.
So I tried the K100d way, that doesn't work either!
I can get into debug on my K110d the second way, but don't need to, any more ideas out there on how to enter debug on the K200d?
Cheers, HG
PPG entries.
PPG entries.
Posted 14/03/2009 - 22:13
Oggy wrote:
Does the K20d have a hidden menu like this?
Its in the Custom Menu.
Tel,
Posted 14/03/2009 - 22:25
i've tried these instructions for K10D with Firmware version 1.30 and had no joy. Is there seperate instructions for version 1.3.
Barrie - Too Old To Die Young
Posted 14/03/2009 - 23:06
You need some russian software to enable the debug mode in in version 1.30 of the K10D
Here is the english translation USE AT OWN RISK!!!!!!
Posted 14/03/2009 - 23:16
That Russian software worked fine for my K10D (once I'd worked out how to use it).
I so glad this kind of thing is easier with the K20D - with AF adjustment included in a normal menu instead of being a hidden feature.
~Pete
Posted 14/03/2009 - 23:19
you have scared me nowYou need some russian software to enable the debug mode in in version 1.30 of the K10D
Is it possible to: 1/ revert to version 1.10. 2/ debug. 3/ reinstall version 1.30... Would the debug hold after the reinstall??
Posted 14/03/2009 - 23:38
Yes sorry, it's just that I don't want the blame if your camera doesn't work anymore.Anvh wrote:
Version 1.30 will overwrite the other version, no settings are saved.
The russian software is really the only way if you want to use version 1.30.
Here's some text on how to do it link
I haven't heard of anyone that had broke their camera with using the software if that helps but still only use it if you really need it.
Posted 15/03/2009 - 08:35
I could try this with my K200d, does anybody know the password the programme asks for???
Cheers, HG
PPG entries.
PPG entries.
Bradford,Yorkshire,
UK
PPG entries.
