Focusing screen shims for K-3
Posted 13/12/2024 - 18:25
Might be worth asking Asahi Photo may be it's something Peter could help in sourcing.
Tipping the shape is a roughly a empty rectangle like this?
Potentially it could be a DIY job using thin aluminum from something like a drinks can, it's feasible to cut thin aluminum with a craft knife and steel rule (or even scissors for the outside), but watch your fingers!
I guess an alternative to aluminum would be plastic, they'd be lots of choices of thickness in various packaging.
Posted 13/12/2024 - 23:44
Rail modelling shops offer plastic card in a range of thicknesses.
Posted 15/12/2024 - 16:48
Or, if you want to go all hi-tech, find someone with a 3-d printer, give 'em the measurements and there you are.
SteveH!
I prefer 'unconventional'.
Posted 16/12/2024 - 00:28
There are lots of things that can be done with 3D printers but I for one wouldn't have a clue how to specify my desires to the operator of one.
Posted 16/12/2024 - 13:55
Thanks for the responses so far. I doubt that a 3D printer could print something so fine as a focusing shim. I would consider DIY solutions as a last resort. The single thicker shim that I do have could serve as a template though it wouldn't be fun working with a craft knife on something so fine.
My K200D shims came from one of the UK official repairers at the time but I don't seem to have any e-mails about it so I don't know which.
Posted 17/12/2024 - 08:07
Another possible DIY solution could be wire from a thin paper clip or copper wire from a cable. Bend it to shape using snipe-nosed pliers, solder up the join if needed. You could even adjust the thickness tapping it flat using a hammer on a steel surface.
Madrid / Edinburgh
Does anyone know where I could get some K-3 shims? I remember many years ago I bought in the UK a set of shims for the K200D for around 30 quid but I think Pentax stopped selling them directly to consumers some years ago. I've looked online and not found anything.
I have read of people using sellotape, which is not a route I want to go down. I could conceivably cut down the shims that are slightly too wide but that seems like it would be very fiddly indeed and would make them even trickier to fit. I could look for the shims for the old K200D but the focusing screens are different so I imagine the shims will also be the wrong size.
Thanks for any help provided.
