Focus Adjstment - K7 with 55-300.
Posted 17/12/2011 - 19:09
Test it wide open at 55mm and 300mm .. if you get the same result then make the alteration on the K-7.
If you get a different result for each focal length then decide which you use the most then adjust for that (I use mine almost exclusively at 300mm) or find a happy medium.
Yes it is fully reversable in menu.
Posted 17/12/2011 - 19:27
Thanks, Mike.
Will let you know how I get on!
Roger.
Roger.
Wiltshire
Some help please:
At what focal length should I test-focus the lens?
At what aperture?
Is the process reversible?
I'm using the Tim Jackson test chart, version V2.00.
Many thanks,
Roger.
