Flu Card does not work after update
Posted 29/07/2015 - 22:38
If you are using a K-3, is the flucard in slot 2? If it isn't it may explain why the camera isn't seeing the card because apparently it needs to be.
Posted 30/07/2015 - 02:16
Yes it's stayed in slot 2 since I bought it. I have noticed the Pentax Forum site has a lot of posts about flu card problems (failing etc) but wanted to know if anyone on this site had experienced this.If you are using a K-3, is the flucard in slot 2? If it isn't it may explain why the camera isn't seeing the card because apparently it needs to be.
Dave
Always blame the equipment!!!!
Posted 30/07/2015 - 14:17
I haven't actually got one, but if I did and that happened I think I would take it out. Do a default setting of the camera. Re-insert it and see if it can be set up again. If that fails get in touch with the supplier for a replacement/refund.
Sussex
I found out there have been two flu card firmware updates now so followed the instructions, and am now showing 'FLUCARD_for_PENTAX' in the Wi-Fi communication menu (of the camera's menu) under SSID, and the correct (latest) firmware version info (00.01.00.01) and contents version (00.01.00.02), but still no icons showing even though they were in the updates and exactly as before. Have I got a duff flu card? Not very good if it is, as only two months old!
Any help would be gratefully received,
Dave
