Flashing F - -
Posted 17/04/2021 - 07:11
Menu C4 line 26 allows you to enable / disable use of the aperture or page 111 of the destruction manual
Chris
Posted 17/04/2021 - 08:23
Excellent - many thanks Chris.
Now I need to remember to change it back when I use the other lenses
Today is a great day - they always are if you wake up
Posted 17/04/2021 - 08:29
I leave mine set as above, imo no need to change it back, then whenever you use an older lens ( non A lens ) it just works as it should
Chris
Posted 17/04/2021 - 08:47
You will need to use the camera in M mode for the lens to stop down.
Posted 17/04/2021 - 11:52
Thank you both - now once the clouds clear, I can watch for the stars
11 years
Near Thessaloniki - Greece
I`ve just taken delivery of a Samyang T3.1 / 14MM ED AS IF UMC ULTRA WIDE Lens. It is a manual lens.
This is paired with a Pentax K1 ii camera.
I am getting the famous flashing F - - regardless of what setting I have the camera in. I realise from previous reading that this is the camera (super intelligent as it is) telling me that it can`t set the aperture. This leaves the camera unable to take any photographs
How can I clear this "error" message?
Many thanks
