Flash Sync speed
Posted 23/02/2011 - 20:39
Max synch speed on the K20D is 1/180th, the same as your K200D, unless you use High Speed Synch (HSS). With HSS I don't think there is a limit and you can use the maximum shutter speed of 1/4000th (I think). You will need a HSS capable flash though.
If you use exposure mode Tv or M, you should be able to select a shutter speed of 1/180th or longer when the flash is attached and turned on.
Posted 23/02/2011 - 20:52
If your still using the RF-602 you won't get any faster than 1/90th without banding. If you don't use the RF-602 you should get 1/180th.
For the big advantage of using the RF-602 I can happily live with 1/90th
TIP: If the transmitter ever goes dead try removing the battery for about 30 secs. It's never happened to me but I heard of it happening to someone else.
Posted 23/02/2011 - 21:43
thanks Peter,Algernon, yes im using the rf602 with no problems so far. we were shopping in Bury at the weekend and i spotted a k20d for sale ,thought it might offer a higher sync speed as well as the higher resolution etc.
regards, tim.
regards, tim.
Posted 24/02/2011 - 11:05
Depends very much on the flash model.
Some will only sync at slow speeds while some will do HSS.
It also depends on the flash output.
For example:
A Metz 58 flash at 1/1 power has a flash duration of 1/125 where as it is 1/33000 seconds at 1/256 power.
For example:
Posted 24/02/2011 - 11:31
It's the timing on the RF-602 that's at fault it must fire the flash too early, so I would think all Pentax cameras would have the problem. The K20D which I have needs 1/90th.
Posted 24/02/2011 - 19:20
the lights are a brace of lastolite 400 , lastolite also do their own radio trigger around the £40 mark. not sure whether this would allow a faster sync speed ?
tim.
tim.
Posted 24/02/2011 - 19:38
They fire the flash slightly late due to signal propagation ! but I wouldn't have thought they were that bad !? It's the timing on the RF-602 that's at fault it must fire the flash too early, so I would think all Pentax cameras would have the problem. The K20D which I have needs 1/90th.
they should be able to manage 1/125 at least, if not 1/160 !
Never had a problem at 1/180 myself !??
K-7 | K10 | DA 18-135 | DA 18-250 | DA 55-300 | DFA 100 |
Blackburn Lancashire
im only able to achieve 1/90 sec on the k200 anything more and i get black lines on the pictures .
