Flash remote trigger for amateur (= not to expensive)
I am an amateur also and bought some "Aputure Trigmaster II 2.4G" triggers.
They are multichannel, very cheap on Amazon (make sure you order the Pentax ones, think the code is MXII-P) and I've not had any problems with them.
They do become temperamental above 160 shutter speed, they will fire the flash when you use your camera to autofocus instead of when you fully depress the button to take a shot. But work at 160 and below and they are flawless in my experience. Range is 120 metres.
You can use them to fire your camera remotely if you buy the cable.
Hope this helps
Southsea
are there options that you are aware about for an amateur like me that does not want to spend too much on a flash remote trigger + 2 receivers?
I just need them to be reliable on a distance under 10 meters.
I bought some chinese ones stating to work within 30 meters, but actually they stop to work over 2 meters.
