Flash meter Conundrum
Posted 03/03/2011 - 20:50
my k10 can dial in 7.1, and any manual aperture lens can be set between 5.6 and 8...
soo, without knowing how to set your camera...
can I suggest this... move your key light a little closer till it rounds off to f8?
using the meter, to you meter each source sepertately? how?
Posted 03/03/2011 - 20:53
You should be able to dial in 1/2 or 1/3rd stops if you have an auto aperture lens. If you are using a lens with manual aperture then it should still have half stops between each f number.
Posted 03/03/2011 - 20:58
in a last resort your meter should allow you to change your iso and it should re-calculte the aperture values.. so changing your iso value (on your meter) intil it rounds the exposure off to a whole stop, then use those new iso and aperture values on your camera... the over all exposure will be the same, just using different iso and aperture combination...
Posted 03/03/2011 - 21:08
The cameras set to manual , but i can only dial in full f stops . i appreciate i can move the lights /turn up or down but it would be easier just being able to dial in the displayed f stop from the flashmeter. maybe its just the k200 ? can you dial in half or third stops on the k10/20 in manual mode ?
regards, tim.
regards, tim.
Posted 03/03/2011 - 21:17
Every cameraI have used that has M mode can dial in half or third stops for aperture. Shutter speed is an other matter though as old film cameras generally only had full stop shutter control.
Posted 03/03/2011 - 22:44
You need to make some changes in your Custom Settings Menu.
Custom Setting 1 - EV Steps, change it to 2 - 1/3 stop.
Custom Setting 2 - Sensitivity Steps, try changing it (see page 89 of the .PDF manual).
You should be able to make exposure changes in steps from 1 EV to 1/3 EV by making these changes in your custom menu and using the appropriate eDial.
Posted 04/03/2011 - 06:51
peter, just off to work , will try it when i get home tonight,
regards, tim.
regards, tim.
Posted 06/03/2011 - 08:26
Peter ,changed the settings ,now working how i want , thanks.
Blackburn Lancashire
any help appreciated, tim.
