Flash for action watersports
Using the correct lens is more important.
What camera and lens(es) do you intent to use?
During the day its fine, its when I come to take photos in the evening just that extra bit of light would be ideal.
Hi
Seen this flash and wondered what people think?
Im going to be using it for taking photos of White water kayaking?
Also is this the cheapest place to get one from?
http://www.srsmicrosystems.co.uk/130/Pentax-AF-360FGZ-Flash.html?referrer=Froogl...
Alex
If you do decide to go with the AF360fgz, then you might be interested in the 2nd hand one which I'm currently selling in the Classifieds Section of Pentax User? Link here: link
Best regards,
George.
Thanks for your interest.
George.
You might find that they object to flash as it could cause distractions etc.
Edmund Burke (1729 – 1797)
Im using a k5 with a 18-250
But i wonder if they are powerful enough for long range in such situation.
I'm still not sure you should use a flash, the K5 can go easily up to ISO3200.
If you plan on doing this more often i think your money is better spend on sigma/tamron 70-200 f/2.8 lens, this lens focus faster but also let more light go through.
You didn't really answer the questions I posed in the previous thread you posted...
You will need a MASSIVE flash to make any difference with a 250mm lens. The effectiveness of the flash decreases by a quarter every time you double the distance (Google "Inverse Square Law"). So, for a flash that works very well at 2 meters, it'll have a quarter of that power at 4 meters, a sixteenth of the power at 8 meters, and a measely sixty-fourth power at 16 meters. It'll be like trying to use a pocket Maglite for portraiture
Maybe a bank of 4 or 8 of the AF360FGZ will help a bit - but it'll put off the kayakers too!
You are better off honing your panning skills, raising the ISO on the K5, and consider shooting RAW (especially when using higher ISO settings) - before you splash out on flash!
You may get more mileage from buying Lightroom 3 Student Edition
http://www.youtube.com/watch?v=cP6a47BQA70&feature=player_embedded
Tamron SP AF17-50 f2.8 Di II -- SMC Pentax 35mm f/2.4 AL -- SMC Pentax-DA 18-55mm F3.5-5.6 AL WR
SMC Pentax-FA 28-70mm F4 AL
SMC Pentax-M 50mm F1.7 -- SMC Pentax-M 135mm F3.5 -- SMC Pentax-M 200mm F4
Alex
