Fisheye lenes
Posted 17/07/2011 - 22:39
bforbes wrote:
What is a diagonal Fisheye?
The fish isn't yet quite cross-eyed. Just wait a day or so.
: Too many film & digital cameras & lenses, oh my!
Posted 17/07/2011 - 22:45
I think he means that it fills the whole sensor so not an circular fisheye.
In the context of the auction description, the vendor do doubt means a full frame fisheye - one that has a diagonal view of 180 degrees. In other words, the image fills the frame, unlike a circular fisheye of up to 220 degrees where there is a circular image within the frame, surrounded by black.
Posted 17/07/2011 - 22:52
thank you. So are all the pentax fisheyes circular
Barrie - Too Old To Die Young
Posted 17/07/2011 - 22:57
Posted 17/07/2011 - 23:26
Pentax have always made full frame fisheye lenses. We have to look to other makers for circular fisheye lenses.
Posted 18/07/2011 - 04:19
So much for humor.
The AOV of any lens is typically measured on the diagonal of the frame its image is projected upon. A full-circle projection on an arbitrary frame of course does not reach the full diagonal. Any frame-filling projection on an arbitrary frame would be trivially 'diagonal'. Even a full-circle fisheye is 'diagonal' on a small enough frame. I find the term "diagonal fisheye" misleading, more marketing crud on par with "35mm equivalent" and crap.factor. It does not describe a characteristic of the lens, just how the lens behaves on a given frame.
Posted 18/07/2011 - 07:45
RioRico wrote:
So much for humor.
Don't worry the humor was noted.So much for humor.
So if I pick a focal length, say 10mm, will a normal wide angle and a diagonal fisheye have the same AOV?
Posted 18/07/2011 - 07:55
No,RioRico wrote:
So much for humor.
Rectalinear lenses loose some degrees due to correction.
F.e. Pentax DA10-17 has diagonal FOV of 180 degrees os APSC sensor at 10mm. At 17mm it's FOV is around 100 degrees, in comparison Sigma 10-20 at 10mm has just above 100 degrees FOV but obviously much less distortions than the DA at 17mm
Posted 18/07/2011 - 13:38
There's plenty of humour about, but if someone asks a sensible question it helps if they get a sensible answer. Otherwise, they might just decide not to bother asking again.
Like all humour, it's all about timimg.
Co. Durham UK
