Fish Supper
Steep
Posted 07/06/2014 - 20:17 Link
276 frames shot, tons of great captures but only one that's halfway sharp!
At Chanonry Point this evening.
Blythman
Posted 07/06/2014 - 20:27 Link
And wasn't it worth it. Bet you were thrilled by the whole experience
Alan
JammyBee
Posted 07/06/2014 - 20:28 Link
Great capture a real moment in time well done
Steep
Posted 07/06/2014 - 20:35 Link
Cheers guys, there were better pictures but none sharp.
Smeggypants
Posted 07/06/2014 - 21:56 Link
Why weren't they "sharp" ?
Steep
Posted 07/06/2014 - 22:05 Link
Here's an example which would have been a far better shot if it had worked. Problems were mostly that the dolphins were quick, here and gone and never in the same place twice.. Although I was using the monopod you have to take into account my shakey hand too... The blur to the left is the back of someones head, the point was very busy as it is most days now.
Edited by Steep: 07/06/2014 - 22:06
Stuey
Posted 07/06/2014 - 22:08 Link
I'd say the first shot was worth waiting for
My Flickr site link
caj26
Posted 07/06/2014 - 22:23 Link
Brilliant shot, inspiring.
dougf8
Posted 07/06/2014 - 22:45 Link
ISO 100 !!!!! On a K-3.
I think you have a little headroom there.....I ramp the K-5 up to 1600 often and above if needed although the IQ starts degrading.
Love the shots BTW...
Lurking is shirking.!
Edited by dougf8: 07/06/2014 - 22:50
Smeggypants
Posted 07/06/2014 - 22:50 - Helpful Comment Link
I prefer that shot.
I noticed both shots were on ISO100. I would have upped the shutter speed quite a bit and used an ISO of at least 800 to 1600. Even higher if necessary
I wouldn't have used monopod either as in such a dynamic scene it would be too restricting and a shutter speed high enough to capture the action isn't going to show camera shake anyway.
dougf8
Posted 07/06/2014 - 22:57 Link
The other thing too, is to dial in a slight underexposure.
I generally have -0.7 dialled in to avoid losing highlights.
I think this will result in a slightly higher shutter speed when shooting in aperture mode.
davidstorm
Posted 07/06/2014 - 23:06 Link
I agree with Doug and Smeggy. On a shoot like this it's more important to get the shots and ISO 800 to 1600, plus a bit of underexposure shouldn't cause you a problem if it helps to keep the shutter speed up. Despite this, the shots you've posted here are definitely worth keeping.
On my recent trip to Bempton Cliffs I was lucky with the weather and the light, but I was under-exposing by 1 stop to prevent whites burning out.
Steep
Posted 07/06/2014 - 23:19 Link
Cheers guys. I've never been that happy with the results at higher iso settings so tend to keep it at 100 as much as possible. The second shot there was at 1/400th so shutter speed/iso wasn't the problem. The more I look at it the more I think the focus is a bit out and that's probably down to using AF-C, the focus point has caught a wave perhaps.
When I go there I'm usually standing for two to three hours. The K3 plus 300mm plus grip is a fantastic combo but very heavy and if I'm having to hold it for that length of time I get very shaky hands/arms so the monopod is a must (and I have a home made rig that gives me plenty of easy movement at the head). I'd use the tripod but that really does get cumbersome.
dougf8
Posted 07/06/2014 - 23:24 Link
The thing I heard in the past was the shutter speed should be at least the inverse of the lens length. So 300mm lens at least 1/300s to avoid blur from shaky hands. I hate hand holding at 300mm as I love coffee. I don't think 1/400 will cut it for action where you are slewing the lens to follow the target. I push the speed way up high using the ISO even when just using a 50mm to shoot the toddler or a 100mm macro.
In lightroom you just slide the NR slider and noise disappears. There is a trade off but only getting a few keepers from 280 shots might be improved by sacrificing a tiny bit of IQ.
Edited by dougf8: 07/06/2014 - 23:26
wvbarnes
Posted 07/06/2014 - 23:40 - Helpful Comment Link
What a wonderful opportunity taken. Well done.
I would use 1/800th to 1/1000th of a second at 200 to 400 ISO. Our current generation of cameras are so much better at higher ISO's. I personally use TAV mode with an upper limit set on the ISO range which of course flashes when exceeded.
