First shots on IR-converted body
Posted 03/07/2011 - 17:40
You're clearly getting there!
Exposure will always be hit and miss as there's no way of knowing how much IR light is present. However, it's always been the same, so I guess there's always going to be an element of surprise when you look at the results.
Posted 03/07/2011 - 17:48
With the filter on the lens the meter saw mostly IR, so that did tend to give more accurate exposures. I'll probably take a test shot and use the histogram to set a manual exposure for critical stuff. Just wondering what else I can do while it is in bits - might try to move the sensor forwards 0.5mm so that the viewfinder focus matches sensor focus.
Posted 03/07/2011 - 19:05
Considering the fact you had a very complicated item in bits and then put it together again I'm amazed at the quality of the shots.
Super conversion and nice results.
Cheers, HG
PPG entries.
PPG entries.
Posted 03/07/2011 - 19:31
Wow, well done for getting the camera back together, I'm impressed.
Lurking is shirking.!
Posted 05/07/2011 - 22:24
Lovely shots.
Well done on the conversion job.
K5, K200d (IR @ 720NM), X-5
Hampshire,
UK
Both on the Sigma 10-20mm at 10mm, 250th at f/8 and ISO 200. Internal filter is part of a Hoya R72 cut to 28x22mm over the sensor. The edges aren't good, the left edge in particular is a bit blurry but I could get used to cropping them a bit...
Exposure is a bit hit and miss, since it is now metering the normal light. The above were about a stop underexposed, while some shots in the woods came out about 3 stops over. It is all a learning curve!
Also on 500px
