First shots on IR-converted body
Exposure will always be hit and miss as there's no way of knowing how much IR light is present. However, it's always been the same, so I guess there's always going to be an element of surprise when you look at the results.
You're clearly getting there!
Super conversion and nice results.
PPG entries.
Well done on the conversion job.
Hampshire,
UK
Both on the Sigma 10-20mm at 10mm, 250th at f/8 and ISO 200. Internal filter is part of a Hoya R72 cut to 28x22mm over the sensor. The edges aren't good, the left edge in particular is a bit blurry but I could get used to cropping them a bit...
Exposure is a bit hit and miss, since it is now metering the normal light. The above were about a stop underexposed, while some shots in the woods came out about 3 stops over. It is all a learning curve!
Also on 500px
