First practice shots with the Bigma
Posted 16/04/2009 - 14:47
You have done a lot better than I did when I first had my Bigma, my shots were almost totally chuck shots. You do seem to be missing the sharp focus and I would suggest you pull back a bit to say 450 or 480 to get the best in clarity.
Of course, a tripod helps a lot as does good light and a subject that stands still, I made the mistake of first trying in December with small birds and thought there was something wrong with the lens, there wasn't it was just me.
Jackie H
K7, K20D, istDS, Optio SV, ME
Most used glass
50mm f1.4, 60-250mm, 28-80mm,
Most used glass
Posted 16/04/2009 - 14:54
Well on the sharp focus. I am trying out a number of things because I feel like it isn't as sharp as it should be. I will do some tests this weekend and otherwise I am going to contact the shop or Sigma.
I know the focus can be adjusted mechanically on the Bigma by slightly moving the rear element.
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
Posted 16/04/2009 - 15:01
Don't be too quick you sound just like me a month ago and now I am delighted, it is a lens that takes some getting used to but when you do it is nice and crisp and lovely soft backgrounds with, what is it called, quality bokeh
Jackie H
Most used glass
Most used glass
Posted 16/04/2009 - 15:06
@thordell
I know what you mean.
But if I compare it to my DA50-200 at 50 and 200mm the DA is quite a bit sharper.
Posted 16/04/2009 - 15:32
Yep what else do we.ve to target practice on
Looks like a good lens, hopefully you can get the 50mm sorted out.
How is the weight of the thing, usable to take on a hike?
My trip don't go on today.. I'm now waiting till it rains to take some shots, they also predicted hail so wish me luck
Posted 16/04/2009 - 15:37
Ok, I did the good 'ole newspaper test with the Bigma. As Thordell suggested it takes some practice. All of the shots below are images which I converted with Silkypix to 800px wide JPEG images. I used the natural fine sharpness setting in Silkypix as that is the one that I mostly use.
The first one is 50mm, the second 100, the third 200, etc towards 500mm
They were all shot using ISO100 and f10. The target was shot from a distance of 4 meters.
50mm
100mm
200mm
300mm
400mm
500mm
50mm
100mm
200mm
300mm
400mm
500mm
20 years
Netherlands
They were all shot out of my hand, I had to increase the contrast and the saturation a little because of the bright overcast.
The second one isn't completely in focus and/or suffers from a little camera shake. SR was on.
K20D + Sigma 50-500 @ 270mm, f10, 1/250, ISO 100
K20D + Sigma 50-500 @ 500mm, f8, 1/160, ISO 100
K20D + Sigma 50-500 @ 500mm, f8, 1/200, ISO 100
