First attempt at HDR
malross73
Posted 01/01/2014 - 20:12 Link
Hi Everyone first go at HDR 3 shots bracketed using Photoshop HDR pro finished off in Lightroom 5.
sComment Image
hot with my istds and M 28mm F3.5 @ F11 any comments or tips more than welcome and wishing you all a happy new year!
Malcolm
Website link
McGregNi
Posted 01/01/2014 - 20:59 Link
A great 1st attempt! Its an appropriate scene for HDR - I imagine the foreground was quite dark and fully in shadow, so the dynamic range must have been very high.
I won't focus on composition etc as the emphasis here is on the HDR I guess, but generally I like the layout of the image -perhaps an even lower viewpont would have been more effective.
The obvious technical point is the halo effect around the main building, which is too obvious to be acceptable - its accompanied by a light fringe also, so whatever specific HDR slider you used that has created this defect needs to be reduced. Alternatively you might try some careful cloning or 'healing brush' type repair work all around the building edges.
I would also tone down the bright 'fluroescent' colours (the cyans and greens on the glass for example) and reduce the shadow brightening on the buildings facade a little - it just doesn't look like the lighting is coming from any floodlamps, so appears a bit unnatural IMO.
To achieve some of this you may want to introduce an additional non HDR version of your shot (exact same dimensions) as a layer in Photoshop, and use layer masking to hide some of the things I've mentioned, revealing the plainer non-HDR underneath. I'd control the effect with layer or brush opacity settings.
And finally I'm not a great fan of ghosts walking through pictures, so I'd try and remove them ... but of course in some situations I appreciate it may be effective, so its a very personal judgement.
Would be great to see how these suggestions work if possible
Edited by McGregNi: 01/01/2014 - 21:07
malross73
Posted 02/01/2014 - 21:13 Link
thanks for the comment very early days for me in processing but have noted the advice and will have a go at your recommendations really appreciate the advice
Malcolm
Website link
