firmware update Metz48
Posted 24/10/2011 - 00:08
If I remember correctly you connect teh flash via usb cable to computer & run the the update file..
Concert photography
Concert photography
Posted 24/10/2011 - 00:10
the whole process seems hit and miss.And I wonder how you know that it has worked??
Chris
Chris
Posted 24/10/2011 - 00:27
I am sure the program tells you it has updated, it was fairly simple affair if I remember correctly... I am not even convinced it is necessary to upgrade...
Concert photography
Concert photography
Posted 24/10/2011 - 16:48
The pdf file contained in the firmware zip file (link) gives you instructions on how to run the update. Once you've run the initial steps on your PC, you have to remember to remove the batteries from the flash before connecting it via USB.
You then have to execute the next step with the flash connected and when that's finished you get the "Ok, Update successful finished" message on your screen. I've never had any problems to be honest - are you not getting this final confirmation?
Posted 24/10/2011 - 19:29
Hi Mark, is it the 'middle one' of the three downloads??
Chris
Chris
Posted 24/10/2011 - 22:21
Yes Chris - it's the middle one if you're running Windows. It comes as an executable file so you just have to double click on it to unzip it (to the location you want). You'll then see a .pdf file (called Metz_mecablitz_FW_Update_GB_Windows_2010) which contains the instructions.
Posted 24/10/2011 - 22:53
Thanks all, I appreciate your help.
Chris
Chris
West Wiltshire
Would appreciate some help
regards
Chris
