Firmware 1.31 causes issue on K10D?
Posted 12/06/2010 - 21:36
Asking perhaps the obvious, but have you checked that the channel numbers match?
Terry
Terry
Posted 14/06/2010 - 17:08
Thanks for your replies guys.
Yes the channels are syncronised.
Because my issues do not appear to have been caused by the firmware update, I have started a new thread here (complete with example photos):
https://www.pentaxuser.com/forum/topic/wireless-p-ttl-flash-test-results-20805
Thanks for your help,
Adam
Adam
USA
I recently updated the firMWARE ON MY k10D from v1.30 to v1.31
Now I am having an issue using wireless P-TTL with the built-in flash in conjuction with an AF-540FGZ.
The external flash will simply not fire when the built-in flash is set as a "controller" in the custom menu.
Can anyone else confirm if they are seeing the same issue when using an external flash?
I tried to downgrade my firmware version for further testing but wasn't able to.
Thanks in advance,
Adam
