Finding a requirement for a half decent tripod.........
Jetsam1
Posted 10/08/2010 - 10:59 Link
Was trying some night sky photography last night seeing as the sky was clear and whilst I have a couple of shots showing enough potential for further experimentation, my cheapo tripod really did show up its limitations.
The K200d did pretty well though with 30 second exposures, though I think if I want to do more of this type of thing I'll need a remote shutter release.......
Truly is never ending this hobby....!!
Any ideas of what's good for under £100 tripod wise?
K5, K200 and several film Pentax cameras!
Edited by Jetsam1: 10/08/2010 - 10:59
Dangermouse
Posted 10/08/2010 - 11:25 Link
I find my little Slik 500G perfectly acceptable for most long exposures. It's a bit low and probably wouldn't cope with big lenses or high winds but I only paid £8 for it. It's also light and small enough to take anywhere.
As for a remote release, there are plenty of cheap infra-red ones on ebay from Hong Kong which are perfectly usable and feel pretty well made too. Try to get the sort with a single button as there seem to be some sellers programming remotes with loads of buttons which were originally intended for camcorders. The extra buttons won't work with a DSLR, plus they're bigger than the single button type.
amilner
Posted 10/08/2010 - 11:34 Link
This should do the job...
Tony Milner
www.amilner.org
johnwhit
Posted 10/08/2010 - 11:42 Link
Agreed, or one of these with the 056 head:
http://www.srsmicrosystems.co.uk/601/Manfrotto-055XPROB-Tripod.html
.....although slightly over budjet!
John
PPG link
In LBA hiatus.
Edited by johnwhit: 10/08/2010 - 11:54
Jetsam1
Posted 10/08/2010 - 11:58 Link
Looks interesting, esp if they are light and compact enough to be easily carried around.
Thought Manfrotto were much more expensive than that? Just shows should have just bought a better tripod in the first place!!
I haven't really used a tripod much yet, just been shooting handheld. Would a good tripod really make a substantive improvement to general photography?
I may be more tempted by the cable release rather than an infra red, so as I can stand behind the camera and not risk photographing myself with the wide lens!
(Still very much a beginner in all of this)
Edited by Jetsam1: 10/08/2010 - 12:15
greynolds999
Posted 10/08/2010 - 13:17 Link
Before you splash out, is it just that the tripod is moving? Have you tried weighing it down - use a long piece of string and tie it to your camera bag (but make sure the bag is touching the floor - it's no good if it's swinging).
And yes, a remote shutter release is essential. Make sure the camera is set to 'mirror lock up' to ensure that doesn't give nay vibrations. You can pick up perfectly good OEM remotes for under a fiver on eBay.
Jetsam1
Posted 10/08/2010 - 13:31 Link
It's a very, very, cheap tripod and the head fell off this morning!!!!
So if I want to do any long exposure work I'll need to get another tripod!
Been searching the forum and Redsnapper keep being mentioned as very good for the money?
Mike-P
Posted 10/08/2010 - 13:42 Link
Redsnapper for me .. not that it ever gets used (or the Redsnapper monopod).
dougf8
Posted 10/08/2010 - 13:50 Link
Slik 88 in the car, perfectly good and less than £30 off the ebay.
Carbon fibre in the house, as its too good to go out much.
Lurking is shirking.!
Jetsam1
Posted 10/08/2010 - 14:13 Link
Slightly off topic for the thread but I'm not entirely sure how monopods can add stability? Still get side to side motion?
MrCynical
Posted 10/08/2010 - 16:10 Link
+1 for Redsnapper. Not the lightest (although they do offer carbon fibre models IIRC) but very solid when it's set up. Also comes with a free carrying case, which is sold separately by most other brands.
Jetsam1
Posted 10/08/2010 - 16:19 Link
Right, pulled the trigger on a Redsnapper after reading plenty of good things about them! Solidity and stability is what I'm after and as I usually have a rucksack I can always just tie the tripod onto it. It'll mainly be used outdoors in the countryside rather than in town.....
Technoblurb
Posted 10/08/2010 - 18:08 Link
I have a read snapper, very solid & functional, however some of the paint did chip off rather too easily on the head. But for what I paid it is far better than the Velbon it replaced. I agree with Johnwhit the Manfrotto 055XPROB is also a nice tripod.
Graham
Daniel Bridge
Posted 10/08/2010 - 18:22 Link
By all means keep the tripod in a case when it's in the boot of the car, but I would strongly advise not using for when you're carrying the thing about - it will be one more reason not to stop and use it.
I use a tripod a lot, but that's because it suits the sort of photography I do. It allows precise framing, repeatability of shots (perhaps your composition's perfect, but there's a stray bit of grass in the shot - remove the grass and re-shoot. Same goes for if the exposure's not quite right, or you're waiting for the sun to come out/go in etc.), and a more measured approach to your photos.
If you're doing street candids, or birds/planes in flight, or a whole host of other subjects, you may find you never use a tripod.
But for me a tripod opens up a plethora of shots that simply wouldn't be possible without it, or at least wouldn't be the same without it.
Dan
cedricd
Posted 10/08/2010 - 18:40 Link
Iv`e carried a tripod for miles withought using it but when needed all those miles paled into insignificance. If you use the 2 second delay for still life shots the mirror raises first to allow the vibrations to die out before the shutter fires. I use very ancient Slik legs with a new ball head and it`s fine.
Cedric
Enjoy life
